Does anyone use CorelDraw for plans?
I have been using CorelDraw for the past 10 years for graphic design. I want to design a few planes and was wondering if anyone is using CorelDraw rather than a strictly cad program and if it is accurate enough for making plans.
I'm also a big fan of CorelDRAW. I've been using it in academia to prepare all the pictures for scientific publications. I's way more intuitive than any CAD program I've tried.
Unfortunately, CorelDRAW is limited to 2D drawings (they used to have some 3D modeling in I earlier versions, but it was way too primitive, so, they've dropped it). I couldn't find a simple way to scale the pictures for printing (may be I haven't looked hard enough?).
I've seen some drawings on the net made in CorelDRAW.
A friend used it to create cnc-files (HPGL), but he draw the plans with FREEHAND and exported it to CD. I think these two programs are quite simular, and accurate enough to make in wood.
plans in corel
I have used the CorelDraw to open plans made in CAD, or still to print plans in JPG or GIF. As I do not know to draw plans , I cannot give my opinion how much to this .
I have some plans in coreldraw now.
It's been quite a while since I did anything with Corel draw but as a very happy TurboCAD user I can't remember Corel having most of the tools I would like for doing my drawings.
Of course anything is possible with enough time. It IS a graphics package after all. But I would guess that it would take you a lot more effort to do so. But then if you're comfy with Corel and don't know jack about CAD then the learning curve would get in the way for a fair while.
Corel
Thats all I use for cad. I do vectoring for Lazer-Works and thats all I use. I also have all my plans scanned in with a large format scanner and besides vectoring the parts I plan on tracing the entire plans and then use the vectors to alter my planes to different versions. I find it 100 times easier than cad and just as powerful as most cad programs. The only thing I wished Corel had was a Diminsion feature like autocad.
Joe
Joe
corel
I have Corel 10 I havent been able to find DImension tools maybe I am looking in the wrong place. I also have never been able to get auto trace to work right either hehe i guess i should read the book but you know how that goes.
Joe
Joe
Joe,
Try the attached pic.
Auto trace is meant for very basic bitmaps like circles, squares etc.
It's better to use Corel Trace for complex stuff. The results depend mainly on how well you prepare the image to be vectorized.
I regularly use traced raster scans for templates, hatches, panels markings etc.
Merlin
Merlin
trace
Thanks Merlin will give it a try I was meaning corel trace to see if it will trace a set of plans. I have them in Tiff format. Right now I like to trace by hand because most raster vector programs give you a bunch of little short lines you have to connect to make it continous and easy to work with. One of the better ones I have used is called Scan Vector but I found out it is a lot faster to trace it myself rather than spend hours fixing up the auto trace. But do you know where the dimensioning tool is?
Joe
Joe
Joe,
Agree entirely about tracing by hand. For the accuracy required to cut parts this is the only way to go. For the panel lines etc. the traced image is quite acceptable and basically saves measuring and drawing on the airframe. Less errors too.
As far as where the dimension tools are, did you look at the picture attachment I posted? You have me confused now
Merlin
Merlin
dimension
Duh ok i saw it i had just copied it hadnt had a chance to look at it. OK I will have to customize my menu toolbar as I dont have it on mine but at least I know what icon to look for.
again thanks
Joe
again thanks
Joe
Joe,
If you hold the mouse button down there should be a flyout which contains the Dim tool. There shouldn't be any need to customize the toolbars.
It's worth noting that if you carefully adjust the settings in Coreltrace and scan by centreline the result is very close to being as good as hand tracing. Happy to compare settings at any time
Merlin
P.S. Attached is a traced drawing which was loaded into Corel and dimensioned. Easily good enough to lay over the plans to see if the engine fits.
Merlin
KS
Corel draw is the perfered cad software for the ULS laser machine. I am using Corel 10 to drive a 2X600 laser machine. The only way to go.
WJF2
WJF2
Guys, i`m a beginner, i bought an Avistar plane and i crashed, the fuselage had minor damages (well , so, so) and the Wings more less, a big problem......Can anyone help me sending me a file with plans in order to build my wings, , suggestions are welcomed,,, [email protected] Thanks in advance...
