Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Cowl
Old 01-23-2009, 06:14 AM
kestrel0222
kestrel0222's Avatar
Default Cowl
I am about to start my new project (1/4 scale Pitts Special) and have a question. Are there any tutorials on how to build a fiberglass cowl? I have built many scale models over my 40+ years in this hobby, but have not yet had to build a fiberglass cowl. I would always build them out of balsa, just like the rest of the model. Any suggestions/advice?
Thank you,
Old 01-23-2009, 08:13 AM
Edwin
Default RE: Cowl
I have an article on our clubs web site. This is how I do it.
Edwin
http://www.austinrc.org/fiberglasseditoral.html
Old 01-23-2009, 08:27 AM
cyclops2
cyclops2's Avatar
Default RE: Cowl
Tom
You should build a lighter than normal cowl. Then just put a correct layer FG cloth over it. Why people glass any long nosed plane is weird. They just create a COG problem. Short nosed planes MAYBE.
Build & finish this plane as usual. See how many ounces you can move around before your COG is.. no good. That weight is your... MAXIMUM... FG covering weight that can be tolerated.
Cowls get the MAXIMUM amount of engine vibration. Ever see cracks ? STAY with wood & paint.
I am a great one to give advice ? I only build in blue foam. [X(]
Rich
Old 01-23-2009, 12:30 PM
kestrel0222
Default RE: Cowl
ORIGINAL: Edwin
Edwin
Thanks for the link!!!
Old 01-24-2009, 03:44 PM
jrcaster
jrcaster's Avatar
Default RE: Cowl
You can carve the cowl to the front of the plane, remove then try this.
http://www.cstsales.com/fiberglass_mold.html
Or you can try
http://www.fiberglassspecialtiesinc.com/
They may have what you are lookin for already made.
