Thrust offset for Twin
I only have one design manual with even mentions such. It reccomends the lefthand engine to be straight-forward, and the righthand one to be tilted 2-3 degrees out. This is a manual of nearly 20 years ago, and things may have changed since.
Try it. Can add washers to remove it later.
Wm.
Wm.
The hobbico TwinStar uses 3 deg out thrust and 3 deg. down. The ads are true about this one. Flys good on one engine. Had a fair amount of single engine runs and single engine flame out on take off when using those OS.25FP's. Solved it by putting TT.36PRO's on it. MUCH BETTER.
Edwin
Edwin
