RCV Engines
SD
RCV Engines
Does anyone have any experience with the RCV engines found at rcvengines.com. I like the 120 "4-stroke", but I am not sure if it is of quality or whats going on in that engine.
I have read all the information on their site and it looks promising, just wounding if anyone has any notes on them.
PA
RCV Engines
> whats going on in that engine. <
It is a four stroke reciprocating piston glow engine with a sleeve valve. I have watched one run on a club member's plane and it ran well. But you had better be prepared for the huge diameter prop necessary because of the gearing.
Dave Segal
Dave Segal
RCV Engines
There was a write up on one of these, I'm not sure which size, in a british magazine that I have. It's a little unusual what with the 2:1 gearing inherent to the layout but the engine got a very good write up for usable power and ease of use. And yeah, they were turning some larger props on it. This would not be an engine for a model that wanted to see higher speeds even by 4 stroke standards. On a large sport scale type biplane or civil type model it would be lovely. Radial cowls? No problem with the big prop.
