Trailing Link Strut Replacement Spring
NE
A few friends and I are working a scratch built jet turbine project. Since I have access to a machine shop it will be my job to produce the retracts and trailing link struts. I am having trouble sourcing the spring needed for the rear struts. I realize that we could buy the replacement springs from someplace like Dreamworks but we are trying to save a little money as we go. I have found a place online called Century Spring but they have a minimum order of $40. I think I can do better. Your help is appreciated.
Barry
Barry
RE: Trailing Link Strut Replacement Spring
Making your own spring from spring stock is dead simple. Most hardware stores have spring stock. They've got it from tiny stuff suitable for replacement springs in you TX to sizes you'd use on a farm. They have both pull and compression stock. And it's certainly nowhere close to $40.
My Feedback: (20)
McMaster-Carr, www.mcmaster.com, has a huge selection of springs at reasonable prices. No minimum that I know of.
NE
Thanks for all of the help. Today I did go to Ace Hardware in search of a spring. The best one I could find was something that has an overall length of 2 1/16 by 3/8 inches in diameter with a wire diameter of about 1/16 of an inch. I took it home to do some research and found that the springs deflection at about 24 pounds was roughly .4 inches. The flying weight of the jet is going to be roughly 23 pounds. I do not think this will be enough. I did look at Mcmaster Carr without much luck either. It is possible that we will have to purchase replacement springs from Dreamworks rc. But for 14.00 dollars a pair I am willing to do a little research since we will be building 4 planes. For me this project is about keeping costs down without sacrificing quality.
Thanks again
Barry
Thanks again
Barry
Both ACEs I shop at have spring stock. It's long lengths of spring in different sizes. You make what you need by cutting a length and bending the two ends to make hooks. It's dead simple to do.
It also allows you to make whatever strength you need. Just make a longer or shorter spring to suit. Or use the next larger diameter, or the next smaller diameter. It's easier than you can imagine.
You may try Autopart stores.
I remember I found a drawer with many extension and compression mid-size springs at PepBoys no long ago.
