sig kougar wings?
sig kougar wings?
i recently acquired some wings that look to be foam with balsa sheeting. my question is how would i join them to a fuselage, as i have no plans for the kit nor do i plan on buying them. i just need some ideas as to some methods of joining them to the fuselage or together. they came from a sig kougar kit
RE: sig kougar wings?
Build manuals for the Sig Cougar.
http://www.sigmfg.com/cgi-bin/dpsmar...FV4.html?E+Sig
In-a-nutshell, , ,
- Square the two faces with a sanding block
- Epoxy together
- Fiberglas cloth taping around the joint
- Cut out servo pocket in the center for the ailerons
- Two 1/2" hardwood dowels in the front leading edge For mounting in the fuselage
- Two 1/4-20 nylon bolts in the rear to srew it in place on the fuselage
In-a-nutshell, , ,
- Epoxy together
