Equavalent material
Equavalent material
Disregarding weight, a model that I am working on, has a one and only fuselage bulkhead made up of 3/16 inch thick balsa. I only got one slab here and it ain't big enough.
Can I substitute in some 1/16 inch plywood, of which I got a bunch of, or is 1/8 inch birch plywood or 1/8 inch light plywood the same strength then?
Wm.
Wm.
RE: Equavalent material
3 pieces of 1/16 plywood glued together with a wood glue like Titebond will probably be as strong and maybe even lighter. Cut the pieces so that the grain will run at right angles to each other. Also be sure to clamp the pieces together while the glue is drying.
ORIGINAL: Laird SS
Wm.
Some models have bulkheads made from 3/32 or 1/8 pieces ( wide strips ) overlapped at the corners and then then the other side is filled in with another piece to make it flush. Makes a 3/16 or 1/4 bulkhead from little material. Best to make the main shape and then cut out the notches for longerons etc after glue has dried.
