Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Another 'HOTS' only bigger !
Reply
Old 05-01-2010, 01:01 PM
  #101
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Another 'HOTS' only bigger !
Attached the bottom sheeting today and bolted the undercarrage in it`s final position.
We put the engine and wing in place to see how the CofG was looking, it`s showing to be tail heavy but it still has to have the spinner, tank, cowl and exhaust added up front, so it`s not too bad.
john josey is offline
Old 05-04-2010, 10:37 AM
  #102
flygilmore
flygilmore's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: john josey
Quote:
ORIGINAL: flygilmore
Looking great!!!!!!
Hows the super hots coming along ? have you decided what engine to use ?
Mine is doing great....I will use the Saito .82. I have the wing, tail and most of the fuse done. Have to add the upper deck sheeting now.
flygilmore is offline
Old 05-04-2010, 02:11 PM
  #103
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking great!!!!!!
Good stuff, i`ll be starting the cowl this week hopefully, the secondthe spinnerpops through the letter box
Old 05-04-2010, 04:41 PM
  #104
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A couple of pictures of the servo and mount instalation.  You can see my prefered elevator set-up with the double ball link top and bottom of the servo arm. As i suspected the throttle servo mounted inverted.
Old 05-04-2010, 04:59 PM
  #105
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had a quick check to see if the battery would fit under the throttle snake in the tank bay, and fortunatly it does.
Old 05-07-2010, 05:07 PM
  #106
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The spinner finaly arrived from the US today, which means i can now carry on and get the cowl done.
The first job was to cut out the 3mm lite ply 'cowl ring' and the 1.5mm spacer to achieve the gap. The two pieces are stuck together with 'wig' tape.
I couldent be bothered to dig out the scroll saw so i had to do it the hard way, 6mm drill bit and the dremel.
Spot tacked to the back of the spinner untill the first piece of cowl holds it in place.
Old 05-07-2010, 05:51 PM
  #107
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The best way i have found to get the correct lenth and angles of the cowl parts is to use two small lenths of sheet balsa cut to 1/2" strips.
Using the sander to get the angles near enough.
It`s much easier to move two separate pieces to the correct lenth/angle than trying to cut it from one.
And then you use this as a template to mark out the 1/2" sheet.
The first piece is cut to the width of the 'top' of the fusalage and the sander is used to take it to it`s final shape.
The first piece glued in place with epoxy.
I maybe stating the obvious here but it may be worth noting that you need to tighten the prop and spinner as you would in use or you will almost certinaly loose the gap that you went to the bother of making the 1.5mm ply ring for.
Old 05-07-2010, 06:32 PM
  #108
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It`s the same idea for the bottom and the two sides which just leaves the two tricky angle pieces which i`ll do tomorrow.
Just checking the gap.
I leveled the fusalage and checked the ply ring for square off the bench before i glued the bottom piece in place.
Luckily with this model the datum line is easy to find and it was just a matter of a couple of pins for the level to sit on.
Old 05-07-2010, 06:49 PM
  #109
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 05-07-2010, 06:52 PM
  #110
Pelle Gris
Pelle Gris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great tutorial John.
Unfortunatly I won´t be able to use it for much this time as I have abandoned the idea of making a cowl. There simply isn´t room because of the big engine that can´t be mounted on a traditional beam-mount.
I guess I could make a fiberglass cowl that would contain the engine, but that´s too much work for a simple everyday model. Besides I would have to find paint that matches the yellow and black of the rest of the model.
Attached are a few pictures showing the build up until a few days ago.
This evening I covered the wing, the fuselage section attached to the wing, the ailerons, flaps, elevators and the bottom of the fuse. I also made a panel that contains the two switches for the radio and ignition, and the two chargejacks for the A123 packs. This will be mounted on the fuselage side aft of the wing within easy reach.
I also started figuring out the connection to the carburettor which will be accomplished by using a standard plastic covered pull-pull wire to open the carb, thereby letting the built-in spring do the closing. A frien uses the same system on his G62 powered Giant Stinger with great success.
I have drilled a small hole through the wing mounting bolts and inserted a small piano "L" which prevents the bolts from dropping out of the fuselage fixing plate. That way I have only two 7mm (1/4in) holes in the bottom fuselage through which I can tighten the two wing bolts. Seems to work OK.
The initial fingers-under-the-wing indicates a slight tail-heavyness, but I will have to check up on that when the model is complete. All-up weight looks to be close to 5,5kg (12lb).
ID:	1432569   Click image for larger version
ID:	1432570   Click image for larger version
ID:	1432571   Click image for larger version
ID:	1432572   Click image for larger version
ID:	1432574   Click image for larger version
ID:	1432575   Click image for larger version
Pelle Gris is offline
Old 05-07-2010, 07:20 PM
  #111
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats coming on a treat mate !!!
Some good ideas, especially the 'pull pull' on the throttle. I`ve never heard of this before but like you i think it would work a treat, i see no downside to it at all.
I kind of wondered how practical the wooden cowl would be on yours, and i do understand what you mean about trying to match the paint to the covering (can be a real pain)
As for the all up weight, i`m not sure how it`s coming along in that area, initially i was hoping for around the 12lb mark but after the first 'weigh in' i was kind of hoping for a bit less.
I would think at this rate were both no more than a week or two away from the maiden flight.
Old 05-07-2010, 08:01 PM
  #112
Pelle Gris
Pelle Gris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Based on the difference in size and the general "lightness" of your build compared to my plywood monster I´m guessing you will come in far below 12lb, more likely 8-9lb. My engine including silencer, ignition and battery weighs in at 2kg (4,4lb), and I have 8 full size servos at a combined weight of around 0,4kg (1lb).
Just on these items alone your should save at least 1kg (2,2lb) if not more.
Unfortunately I won´t be able to work on the Hots the whole of next week, so it will proporbly be at least 2 weeks before mine takes to the skies. But I´m looking forward to it.. :-)
Old 05-07-2010, 08:52 PM
  #113
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
8 or 9lb ? oh that would be sweet !    i`d be lying if i said i didn`t have any concerns about the 91 glow being enough for it.
Old 05-08-2010, 08:11 AM
  #114
Pelle Gris
Pelle Gris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Todays update.
The wing is now finished and the only thing left to do is to adjust the length of the linkages. These are made from M3 threaded rod which will be stiffened by inserting them into a 4/3mm carbon tube.
There is still some work left on the fuselage but it will be ready to cover soon.
ID:	1432871   Click image for larger version
ID:	1432872   Click image for larger version
ID:	1432873   Click image for larger version
Old 05-11-2010, 02:23 PM
  #115
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Managed to get the cowl finished today.
A few pictures of the final pieces being added.
I used the bandsaw to get the awkward angles cut
If it`s not ready by this weekend it definetly will be for the following.
Old 05-12-2010, 04:56 PM
  #116
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pretty much the last thing to be done apart from the covering is the hole for the engine and exhaust.
Getting there.
Old 05-13-2010, 07:03 PM
  #117
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just checking the gap before final sand and covering.
Old 05-13-2010, 07:15 PM
  #118
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I weighed the model again and it came out at 1.9 kilos and then weighed the engine, exhaust, undercarrage, tank and most of the parts still to be fitted which came out at 0.9 kilos. the only things that have to be added to that are the wheels and aileron servos. so going on that, it`s looking good to end up at under 7lbs which i`m absolutley delighted with.
Old 05-19-2010, 07:07 PM
  #119
Pelle Gris
Pelle Gris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have been beavering on with the Hots build and I´m quite close to being finished.
Got the last of the covering done today. I may throw on some more black trim along with some markings, but that can wait. For now this will have to do.
I also made the last of the servo extensions and mounted the tail servos along with the throttle servo. Having finished that I have started doing the final fitting of ignition, RX and batteries.
I will be fitting two A123 2S 1100 packs, one for the RX and one for the ignition. I know that this is not much capacity, but I already have the packs and having the charge jacks on the outside enables me to charge during the day with ease. I have a Hyperion LiFe 2S 2100 pack on order. This is destined for my Pitts Special, but could be mounted in the Hots if I find that the 1100mAh capacity is a bit short.
BTW. I also got the new sticks I ordered for my TX. These have 3 position switches at the top which enables me to have my fingers on the sticks at all times even while manipulating flaps, retracts etc. For this model I will have 3 flight phases, Normal, Aerobatic and Landing, all switched by the right switch.
ID:	1438964   Click image for larger version
ID:	1438965   Click image for larger version
ID:	1438966   Click image for larger version
Old 06-08-2010, 02:27 PM
  #120
flygilmore
flygilmore's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So...how are the Hots coming along? Been quite a while and no update!!
Old 06-09-2010, 08:02 AM
  #121
Pelle Gris
Pelle Gris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well. I got mine finished lacking only final balancing. I have to move the GC forward 1 to 1,5 in.
But my most immediate problem is that I can´t get the engine to run properly now. It ran fine on the teststand but after being mounted in the model it will not idle anymore. It will run on the fuel pulled forward when choking, but as soon as this is used up the engine quits.
If I go to at least 1/3 to 1/2 thottle immidiately, the engine will keep running, but as soon as I lower the idle anymore the engine will quit.
The carb is a new WT610 bought on ebay, but thinking that it may have been used afterall I rebuilt it with new gaskets and diagphram, which made no difference. I tried putting on another carb I had available and with this it will idle all day long. So I´m down to trying to blow out the WT610 or maybe soaking it in some sort of cleaning agent.
Final weight before balancing came out a little heavy at 13,2 lb, but the engine should still be plenty strong.
Old 06-09-2010, 08:09 PM
  #122
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My brother and his good lady had a little baby boy last weekend, so thats kept me away from the hots for a bit plus all the general maintenance for the stuff i fly on a regular basis, but normal service should be resumed in the next day or two.
Old 06-13-2010, 06:49 AM
  #123
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats the covering finished, just really the final assembly and test flight at the weekend.
Old 06-16-2010, 07:14 PM
  #124
Pelle Gris
Pelle Gris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just maidened my Hots this evening.
I put in 6 flights and it seems to fly very nicely although its a bit touchy on both elevator and ailerons. This could be caused by a slight tailheavyness, but it´s quite managable.
Final weight with 12oz of lead in the nose is 13,8lb, and with the 35cc Bully it still has unlimited vertical. I plan on changing to a prop with more pitch, possibly an APC 18x12 or a 16x12 3-blade, to lower the rpm and thereby cutting down on the noise. It´s not bad with the rather large Zimmermann DA-50 canister, but the engine takes an APC 18x10 up to about 7900rpm on the ground, so it gets a bit noisy going full steam.
The model seems to track very well at speed. If you put it into a 20° dive, it stays in a 20° dive. Same thing happes going upwards.
I have programmed an "Aerobatic" flight phase giving me full span ailerons by having the flaps travel with the ailerons. With about 25-30° throw rolls are VERY fast. Maybe 2 rolls per second, so I have programmed 30% expo, but I think I will try a bit more.
This setting also slaves the ailerons and flaps to elevator input. So when putting in up elevator both flaps and ailerons travel down 10° or so. The opposite happens with down elevator.
During the "Landing" phase the flaps goes down about 40° and the ailerons about 30° I guess. This provides some braking and there is still plenty of aileron control.
I will try to snap a few pictures the next time I´m at the field.
Old 06-16-2010, 09:57 PM
  #125
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Pelle Gris
Exellent report
Just as a matter of interest where did you put theCofG for your first flights ?
I`m hoping to get this one ready for the weekend (fingers crossed)
Reply
Display Modes
