Need Laser Cutting Advice.
NC
I'm working on a set of Cad files to send off to get laser cut. I know that the laser has a .08 Kerf. So when I'm designing, say the wing rib spar slot or former stringer slots, what should be the dimensions of say a rib with a .250 spar slot. Would the spar slot offset on the cad laser file need to be larger or smaller. ? Do I take the size of the Kerf and half it for my offset? Would the .250 slot need to be .254 or .246 ???
RE: Need Laser Cutting Advice.
That is something you should be asking the person who owns and is compiling the machine code for the laser cutter and doing the cutting.The offset for kerf also depends on the direction of the cut. Usually G41 (left kerf or cutter compensation), outside profiles are cut CCW and inside profiles (holes) are CW. Most programming software will compensate for the kerf at the machine controls.
Jim
Jim
I think we have a terminology problem.
The actual laser will cut an approximate .008 to .015 cut in the wood, depending on the wood thickness and type..
The "Kerf" is a space placed on the part to stop the part falling out.
For the spar size, draw to the actual dimension and the laser will cut it slightly oversize.
Leave at least a 1/8 space around the edge of the standard wood size your cutter will be using.
Also check what color the cut and engrave lines need to be.
Hope this helps.
Bob
Hope this helps.
Bob
ORIGINAL: Puff The Magic Dragon
This is sort of a loaded question, for is no memtion as to exact thickness of material being used. Last week had a saleman show me his Fine Cutting, but the laser displayed a .015" wide kerf in thin Plywood. On balsa the very same part gave a .008" wide kerf. Sort of depends you know. But I usually draw the line in Autocad to center of line, and disregard any kerf. That, if required, can be handled via software inside the laser machine.
I usually set lines from parts about .050" apart from one another. As the thin resulting section in between two can catch fire, and then you got junk. Only use the normal 1/8 inch at the exterior borders. Thus with the reduced tolarances can pack the parts in tighter to one another and posibly eliminate one whole sheet. It wokrs now for past ten years.
Wm.
My Feedback: (60)
AZ
I suppose you will get as many different answers as you get replies but I have found on the laser cutter I use that .005 offset to allow for the kerf works pretty good for most balsa and plywood parts in the thicknesses generally used for models. I simply draw the part to size and then offset the line in CAD by .005 to the proper side. On outside cuts you need to offset to the outside, i.e., make the part larger. On inside cuts you need to offset to the inside, i.e., make the part smaller. Below is an example. The blue line represents the actual size of the part as drawn in cad while the red line is the laser cutting line. Please note I have exagerated the offset in the sample below to make it obvious.
No offense Bob but I think the terminology error lies with your use of the word. Here is the definition of "kerf":
Main Entry: kerf
Function: noun
Etymology: Middle English, action of cutting, from Old English cyrf; akin to Old English ceorfan to carve — more at carve
Date: 1523
1 : a slit or notch made by a saw or cutting torch
2 : the width of cut made by a saw or cutting torch
ORIGINAL: limeybob
The ''Kerf'' is a space placed on the part to stop the part falling out.
Main Entry: kerf
Function: noun
Date: 1523
ORIGINAL: limeybob
Does it mean that the AutoCAD file (drawing) that you send to the laser cutter has to have two lines in different colors?
ORIGINAL: Chad Veich
Main Entry: kerf
Function: noun
Date: 1523
Main Entry: kerf
Function: noun
Date: 1523
Also, I use a .004" offset for all of my parts; 1/16-1/18 balsa, 1/16 A/C ply and 1/8 lite ply and everything fits real nice. The laser guy I am using has never done R/C (balsa) before and commented that he found the variances in the wood density to be a little troubling. If he slows the rate, the cut will go all the way through the dense parts, but widen the kerf through the soft spots. If he speeds the rate, the hard spots will not always cut all the way through. I advised him to set his speed based on the softer balsa. I can x-acto the parts that don't cut all the way through, and a little sand paper takes care of any tight fits.
ORIGINAL: LNEWQBAN
Could you explain this a little better for me (I have never ordered from a laser service)?
Per #8 noted above, to which side does the offset go when using one line to cut two parts? I get called up quite often to have one part line cut for two parts. Such as to the wing rib as illustrated. A forward half and a rear portion. Usually at where dihedral braces go in at or at wing tips. And thus you have now created a gap. I think something is missing here then, for one example does not fit all situations.
And as per #6 noted above the term locking TABS is correct, for we have been using such since the late 1980's era. Years ago, had a LISP program wrote up to create these, and gap varies between hard woods like used in plywood, and very soft woods like on balsa.
Wm.
Wm.
UT
I use a product called SheetCam to generate my offsets and holding tabs, it's not an expensive program and well worth it if you do much of this type work.
Richard
Richard
My Feedback: (60)
AZ
ORIGINAL: dreadnaut
My Feedback: (60)
AZ
ORIGINAL: CoosBayLumber
My Feedback: (60)
AZ
ORIGINAL: dreadnaut
I have a macro that changes the color of the lines I offset. This is useful for when I go back to delete the original so that I do not delete the kerf'ed profile by mistake.
