V Tail design
V Tail design
Am converting, bashing, a Venture 60 kit to make a kinda scale like Beech Bonanza V tail. Question is how to do the tail.
As near as I can tell from photos looks like I want to go about 50% more than current horizontal stab area for total control surface area and about 40% of that total for ruddervator area. Full size plane has about a 120 degree angle between the surfaces.
Thoughts?
Tom
Thoughts?
Tom
RE: V Tail design
Tom,
I designed a Bonanza about 25 years ago. It was powered by a K&B.60. I made sure that the horizontal projection of the V-tail was the same area of an equivalent horizontal stabilizer required for this size model, about 25% of the wing area. The same applied to the vertical stab. The model flew great with no noticeable difference than a regular empennage. Dan.
RE: V Tail design
The bend to the Vee tail is quite critical. It was discussed in the Aero-forum a good year ago or more, but think the proper interior angle lies between 110 and 120 degrees. No where near to 90 degrees.
I have a couple of A/C with Vee tails and all seem to be at about 114 degrees.
Wm.
Wm.
RE: V Tail design
Fullscale sailplanes seem to have the angle between the 2 surfaces ~110 degrees. I built a Spirit sailplane with a V- tail. I added the areas of the stab and rudder to arrive at the dimensions used. The surfaces were, you guessed it, 110 apart! But as stated previously- you will be able to arrive at these dimensions since you are building a scale design. Good luck
