Building a Bleriot XI
1 Attachment(s)
Hello,Wanting to build the Bleriot XI aircraft that crossed the English Channel, I searched for blueprints off it. I have run into a little problem.Attached are two blueprints of the Bleriot XI. I don't know which variation is the correct one. I want to use the one that crossed the English Channel. Notice the wheel structure and the body is a little different.Please, NO google it. I have already tried that.One more question, I am going to build the body out of blasa wood and-I think- the wing out off foam. I am also going to use a 250 size electric motor. Looking at some other aircraft on the market, I am thinking about making the wingspan 38 in to 40 in. Any suggestions on size would help-this will be my first attempt of making a radio control airplane from scratch. :)Thanks a bunch,J3dF
RE: Building a Bleriot XI
You might want to check out [link=http://www.rcgroups.com/forums/showthread.php?t=996104]this thread on RCG[/link]. The builder might be able to answer your questions. He's done some incredible work on his 1/2 Scale Bleriot XI.
RG |
Picture of the one http://en.wikipedia.org/wiki/File:Av...ot_XI_1909.jpg
First, thanks for the link R G. It will help a bunch. In the picture TFF posted, the wheel struts connectedat the middle of the wing.The problem is I have seen pictures with the wheel struts connected at the front of the wing. I don't know who to believe. I want it to look like the one that cross the channel. </p> |
Thanks ya'll.I have decided to go with the drawing with the struts in the middle of the wing. I watched the video of the real takeoff and I think this is correct.Anyways, it shouldn't be to hard to chance.
