Originally Posted by WacoNut
(Post 11965544)
I would not recommend it, the DLE-35 would be marginal at best. I would go with at least a 50cc engine. The DLE-55 would be a good choice.
Anthony or anyone else with a Pepino Waco, Is 1/4" down and 1/2" up really enough aileron throw?? sure seems a bit on the small side. I have a 60cc gas engine set up for mine. Dave
This is my first time using Minwax polycrylic. do you use a primer between the poly and the finish coats? Still looking for input on control throws, thanks Dave
