Retractable landing gear
Hi, I'm need to use retractable landing gear in my plane ( it is similar to Shadow UAV ), I need to lift fuselage at least 15" of the ground. My main worry is front wheel, I can't fold it frontward because my fuselage is too small ( about 40" ), plane weight is about 45 lbs. Could You advise me some simple yet effective solutions?
Thanks, Mark |
RE: Retractable landing gear
1 Attachment(s)
What scale are you building? Unless you're building the full size plane, you don't need a 15" nose strut. AND, that gear doesn't look retractable.
Dr.1 |
10' wingspan, 7' long
I need retractable landing gear and that 15" space under fuselage. Mark |
