RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Scratch Building, Aircraft Design, 3D/CAD (http://www.rcuniverse.com/forum/scratch-building-aircraft-design-3d-cad-174/)
-   -   Unassembled Robart hinges? (http://www.rcuniverse.com/forum/scratch-building-aircraft-design-3d-cad-174/6818364-unassembled-robart-hinges.html)
abelard 12-28-2007 08:22 PM
Does anyone have experience with using the unassembled version of the Robart Hinge Points?
The hinge pin in the assembled units is actually a very small rivet, obviously installed with a special tool. Robart advertising offers no information about these pins or the tool. So what do people use? Thanks...
rj
b.bixel 12-29-2007 01:34 PM
RE: Unassembled Robart hinges?
I really think those hinges are best used for a removable control surface. One properly fastened long pin through all the hinges.
abelard 12-29-2007 05:11 PM
Actually I'm not as interested in making the surface removable as I am in getting precise alignment of the hinge axes. It would be nice if I could use a single long wire, under tension, to line up the hinges on one surface and epoxy them in place; remove the wire and assemble the hinges with rivets; then epoxy the other end of the hinges into the mating surface. Precise alignment, but no long kludgey-looking wire.
rj
