Fiberglass unionvill 6' & 8' Beaver
BC, CANADA
I have the plans & thinking about fiberglass fuse & foam wing
i have a MDS 61 or magnum 61 for it
will this work
will this work
No reason why it shouldn't work for the Beaver. It does with most pattern planes. Lotta work to build the plug and care to watch the weight.
BC, CANADA
For the 6' beav the 61's will be overkill. For the 8 ftr it might be just enough .... The kit specs for a 61-90 2 stroke..so if your model is lighter, then no problem....But if is heavy then you can always put something bigger in....
Keep me informed on how the plug and the model comes out I might be interested in one too...if you don't mind making another one that is ....
