Go Back  RCU Forums > RC Airplanes > Seaplanes
Reload this Page >
Nitroplanes Canadair 80"
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 06-16-2011, 08:42 AM
robbie9859901
Default Nitroplanes Canadair 80"
Here's some pics of the main gear that I made for this model. Nose is next. Has any one done this yet? I made a couple extra sets of gear.
ID:	1624051   Click image for larger version
ID:	1624052   Click image for larger version
Old 06-16-2011, 10:43 AM
teresos
teresos's Avatar
Default RE: Nitroplanes Canadair 80
These gears are "Dumas" design.Do you use cnc machines ?
They are well made...congratulations !!!
Take a look here :
http://www.rcuniverse.com/forum/fb.asp?m=9489518
Old 07-14-2011, 04:49 PM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
I bought a set from Robbie,, they came today and look fantastic.
I have more questions now though.
1-could you email me the reduced size CAD file so I can print out a template for the attach points or just give me the reduction %
2- which robostrut # do you have in the picture?
3-How did you plan on pinning the strut brackets
4-?? I'm sure I'll have more
BTW,, Thanks
Old 07-14-2011, 06:31 PM
robbie9859901
I thought that I would use a robart 660 cut down. The shock sissors will have to be modified to shorten the shock absorber from 1" to about .5". I thought that I'd put a set screw in the brackets surrounding the strut along with J.B. Weld. I reduced everything by 10% and then reduced that 8%. I can send you measurements from point to point via email.
Old 07-14-2011, 07:38 PM
scale only 4 me
My Feedback: (158)
So you want to shorten the "droop" to .5",, I'll have to think about how to do that,,
I see in your mock up it seams you changes the strut angle from scale, I assume so you wouldn't have to bend the axle or the lower strut,, that seams like a reasonable compromise,, I was thinking I could always cut and re-weld that strut angle,, might not be worth the trouble though
should be a fun project
Old 02-23-2012, 08:57 AM
scale only 4 me
My Feedback: (158)
Curious if you ever did more work with this set up??
The set I bought from you has just sat in the bubble wrap while I worked on other projects, slowly,, I kinda lost interest and it's all up for sale now,,
I really need to stop doing that. maybe if you've made progress I can get inspired to tackle this project.
Old 04-06-2012, 04:54 AM
Mustang Fever
Mustang Fever's Avatar
robbie:
How's the 415 build going?
I'm really thinking about one of these. Seems like a lot of airplane for the money, and I'm hooked on seaplanes anyway. Would make a great electric converson with a pair of Turnigy G46s.
Old 04-06-2012, 05:59 AM
robbie9859901
I haven't touched it since last fall. My business is winter oriented and have been too busy. I have the main gear installed on bulkheads in the plane. The air cylinders are installed and everything can be moved by hand. I'll post some pictures.
Old 04-06-2012, 06:07 AM
Mustang Fever
Thanks, mon, looking forward to em.
After looking at another post and finding out that electric RTF weight is between 12-13 pounds, I think I'm gonna go for some bigger motors. Gotta recalculate, anyway.
Old 04-06-2012, 06:38 AM
Mustang Fever
robbie:
What size are the spinners? I'm going to use tru turn (tractor and pusher).
I ran some numbers on the Turnigy G60-500, using Markus' ecalc, and they look real good with 13x6.5 APC E props.(63mph and 17# total thrust on 41A apiece) That arrangement would allow going up or down in power and amperage by merely changing props, too.
