Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Pulse 60 XT on floats
Reply
Old 09-13-2011, 05:49 AM
Mustang Fever
Mustang Fever's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Pulse 60 XT on floats
Just completed my first test flight with this setup. I'm very pleased. Pops up on plane quickly, short takeoffs, and nice handling. With an OS 75AX and a 15x5 wood prop, there's plenty of punch for playing.
The specs are:
36" plans built Fly Baby floats from http://www.rcmplans.com/index.php?ma...oducts_id=1615
This kit is about the right size, too: http://www3.towerhobbies.com/cgi-bin...?&I=LXJ929&P=7
Two large 60 size struts. These will work fine, but the aft one must be bent in the center to conform to the wing's dihedral: http://www3.towerhobbies.com/cgi-bin...?&I=LXJ924&P=0 I used some slightly longer bolts at the standard landing gear and wing hold down areas to mount the struts.
I have the CG set at four inches from the LE for both land and sea operation, the wing incidence at two degrees positive compared to 0 for the float tops, and the CG is 1/4" aft of the steps. I added the ventral fin (held on with the tail feather nuts) just in case. There's almost no float extending beyond the spinner, maybe 2", but up elevator keeps the prop out of the water during taxi, so who cares. The smaller the floats the better in this game, I think. No water rudder. If it won't go where I want it to, I just idle back and she'll weathervane into the wind, then it's easy to steer with the air rudder and throttle.
Very quick to setup at the lake: four bolts holding the struts and wing in place, and away you go.
ID:	1661618   Click image for larger version
ID:	1661619   Click image for larger version
ID:	1661620   Click image for larger version
Mustang Fever is offline
Old 09-13-2011, 06:20 AM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Pulse 60 XT on floats
Looks good, but the blue has got to go!
MinnFlyer is offline
Old 09-13-2011, 06:36 AM
Lnewqban
Lnewqban's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
....and the tail wheel
Is the water rudder effective enough?
Lnewqban is offline
Old 09-13-2011, 07:51 AM
Mustang Fever
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, I think I'm gettin ready to bring the floats in and repaint them black. They were originally on a 4*60 that bit it about five years back, and it was blue and red.
The tailwheel is permanent- part of the air rudder.
No water rudder. Doesn't seem to need it, but it would be easy to stick one on the TE of the ventral fin and couple it to the air rudder.
Old 09-13-2011, 01:55 PM
JimCasey
JimCasey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You might watch the wood prop closely. Every time I tried one on a waterplane, I found out "they" were right. Mine splintered.
JimCasey is offline
Old 09-14-2011, 07:58 AM
Mustang Fever
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike:
I think this looks a bunch better.
I flew it again about 8 this morning, and I am really impressed. So much so that I plan to get the 25E version and the floats. (I have a Rimfire 32 w/mount, esc and some 3300 4S packs to put in it.)
She does like to slow down and be flared on landing, tho, or she skips a little. Just like off the wheels.
ID:	1662255   Click image for larger version
ID:	1662256   Click image for larger version
Old 09-14-2011, 08:04 AM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Much better!
One trick I have learned is: When properly balanced, you can start to settle her in for a landing, then just before it touches down, add a few clicks of power.
If you time it right, the power is too late to keep it from touching down, but it gives it a little more pull to overcome the sudden increase in drag the water provides.
It makes for some really smooth landings!
Old 09-14-2011, 09:22 AM
Mustang Fever
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll have to try that. Sounds like it would work good for a touch and go, as well.
Old 09-15-2011, 07:04 AM
Mustang Fever
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, Flintstones water rudder. Will be clear of the water when on plane, so should work ok. If not, will be very simple to remove.
I put it on because yesterday I got into a situation where it would have been useful- close to shore, pointing downwind, and there wasn't enough breeze near shore to make her weathervane, and I just had to wait until she climbed up on a rock at idle before she'd turn away and I could motor out.
ID:	1662605   Click image for larger version
ID:	1662606   Click image for larger version
ID:	1662607   Click image for larger version
Old 09-15-2011, 07:08 AM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You should have angled the part that drops below the ventral fin back. The way it is, it will pick up any vegetation it runs across
Old 09-15-2011, 07:09 AM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In fact, it would be better to cut it off at the bottom of the ventral fin and attach an extension with a single screw so that if it hits a rock, it will just swing back instead of getting torn off.
Old 09-15-2011, 08:47 AM
Mustang Fever
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had one like this, only pivoted like you said, on the 4*60. It didn't pick up any vegetation, and the first time I hit a rock it broke off. Go figure.
Old 09-16-2011, 06:49 AM
Mustang Fever
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The H2O rudder worked great, but using iron on for hinges didn't. I ended up removing it after the first flight at this morning's lake session.
Without a doubt, this is one of the best flying seaplanes I've ever seen, and I rate it right up there with my Mikulasko Arrow on the fun scale. It has plenty of punch for aerobatics, and does lovely spins. A little slow on the entry, but nose down and pretty once it's in them. Probably an indication that I didn't need the ventral fin, but it stays. Recovers instantly upon control relaxation. Does the prettiest axial aileron rolls, right up there the Bullet (land based version of Laddie's Arrow). The floats hanging down have something to do with that, I think, as well as contributing to great roll stability. (It has to be held in a bank, or it will straighten itself up.)
Gonna dig up some DuBro plastic hinges and take another run at the water rudder. It really needs it when the wind comes up. Coming up on partial plane and kicking it around with the throttle makes me look unprofessional. [8D]
Reply
Display Modes
