Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Prop spray
Reply
Old 10-12-2011, 11:43 AM
dabrown
dabrown's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Prop spray
Is there a good way to stop water from being sucked into the prop? My quasi-modified-Sportster 90/120 uses a 16-8 prop which is around 5" above the water but it will always pull some water and that really slows it down.
Would adding strakes or deflector strips to the inside edges of the floats do any good? Or is it that the prop is sucking water directly from the surface of the lake...
I will be going to a shorter prop this weekend, maybe a 15-10 or 14-10 if I can find such.
Dave
ID:	1673472   Click image for larger version
dabrown is offline
Old 10-12-2011, 12:46 PM
box car
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Prop spray
Got any pictures taking off in that pool, one landing would would nice too. Adding a spray rail to the inside of each float could help.
Ken
box car is offline
Old 10-12-2011, 01:36 PM
dabrown
dabrown's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sure, I do touch and goes all the time in the pool. The only hard part is dodging the swimmers... No pics of it though too hard to fly and operate camera at the same time.
May go ahead and try the spray rails. Hopefully can find some easy temporary way to test it out before spending alot of time...something involving duct tape I'm thinkin'
Dave
dabrown is offline
Old 10-12-2011, 01:53 PM
TEBerg
TEBerg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I cut my spray rails out of a sheet of ABS. The float plans (Great Planes) included a pattern. I just stick them on the floats, which are finished with monokote, with double-side servo/foam tape. Works great and I have only had to replace tape twice in about 6 years.
It really keeps the spray off your prop.
TEBerg is offline
Old 10-13-2011, 05:58 AM
dabrown
dabrown's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like you did exactly what this Cessna has. For some reason I was thinking of something different. Obviously I wasn't thinking at all.
I have the ABS and double-sided foam tape...problem solved!
Thanks.
dabrown is offline
Old 10-13-2011, 08:48 AM
TEBerg
TEBerg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wish I could take credit, but it was right off the Great Planes instrucitons. They call them splash strips in the instructions and spray rails in the drawing, here are pages from the instructions that shows what they suggest and the patterns.
Good luck, let us know how it goes this weekend.
File Type: pdf
TEBerg is offline
Contact Us Archive Advertising Cookie Policy
