Go Back  RCU Forums > RC Airplanes > Seaplanes
Reload this Page >
sea plane for saito fg-36
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 07-10-2012, 09:47 PM
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
Default sea plane for saito fg-36
whats a good float / sea plane for a saito fg-36 can be scale or sport.
Old 07-12-2012, 06:53 AM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
Default RE: sea plane for saito fg-36
Well, picking a plane is such a personal decision,, a often modelled 1/4 scale Cub would fit that engine nicely I would think
good luck
Old 08-06-2012, 05:24 PM
jrf
My Feedback: (551)
We can't answer that question without knowing what kind of flying you like to do. Trainer, scale flight, mild aerobatics, pattern, 3D, racing?
The FG 36 is roughly equivilent to a 1.20 two stroke or 1.50/1.80 four stroke glow and there are plenty of choices for those engines in each of the catagories above.
Pick one you like, but make sure to get enough wing area to carry the extra weight.
Jim
Edit: You can put almost any airplane on floats, so don't limit yourself to the usual sea/float plane designs.
Old 08-06-2012, 06:03 PM
JimCasey
JimCasey's Avatar
The 120-size Seamaster or Mariner, if you can find one. The Mariner is better. If you find plans for the Seamaster 120 you can take a lot of weight out while still adding strength. It was not super well designed. Heavy without being strong.
Old 08-06-2012, 06:49 PM
Wayne22
Wayne22's Avatar
If it were mine, I'd put it in a 1/4 scale cub - it will take the weight (I had a G-38 in mine..)
