Go Back  RCU Forums > RC Airplanes > Seaplanes
Reload this Page >
what side for the water rudder
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 08-12-2012, 01:38 PM
goirish
goirish's Avatar
Default what side for the water rudder
I am putting a water rudder on my floats. is one side better than the other for the rudder. I can go either side.
Old 08-12-2012, 01:44 PM
TEAMERICA
My Feedback: (77)
Default RE: what side for the water rudder
My experience:
Most airplanes pull to the left when you throttle up. So the slight amount of drag on the right float may compensate for that.
Most float planes that I have seen with only one water rudder have it on the RIGHT float.
Old 08-12-2012, 02:40 PM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
Usually just ends up on the side that's make it easier to run the linkage aka same side as the rudder horn
Old 08-13-2012, 03:24 PM
JimCasey
JimCasey's Avatar
Kinda what Teamerica said, but not:
Almost always you need a little right rudder after takeoff.  Put the rudder on the left, so you'll be compensating for its drag with right rudder.  When you lift off it will be next to transparent with the rudder input.
Old 08-13-2012, 06:39 PM
Charlie P.
Charlie P.'s Avatar
My two float planes both have the waterrudder on the left float. Really is determined by which side your rudder horn is on for the tail if you are linking to that mechanically.
But any Viking worth his salt knows the steering board (star bord) goes on the right side when facing the bow. ;-)
