Hansa-Brandenburg W.29 ARF
My Feedback: (158)
RE: Hansa-Brandenburg W.29 ARF
Well I tested with Moving the CG forward, I added 3.4oz of lead atop the dummy engine. It made no difference, the floats just don't have the reserve buoyancy to support the weight of the plane properly. That couple with the scale like tapered tail of the floats make it drop there easily or at least first.
I was going to taxi test, but I'll have to wait to do it where I have a recovery boat if needed,,
I'm really unhappy I choose to be the guinea pig, good news is I have the skills to fabricate a set of floats, I feel sorry for any newbies who hope it will be good out of the box
#31
ORIGINAL: pimmnz
Built a 100'' version a long time ago, 9lb with a FS90. Taxiied on grass with those flat bottom floats, never needed water...never actually got wet...the surface area of the floats and the AUW meant that the loading on the floats was so low that it could be operated of grass.
Evan, WB #12.
Evan, WB #12.
I used to work at a field called Cumbernauld. One of the chaps had a Cub and, when summer arrived, he'd fit floats and take-off, using a wheeled dolly ... he'd be away for months, flying out of the Lochs.
But, when he returned, the mechanics took a fire hose and doused the grass alongside the runway ... then the Cub would land on the wet grass. It was a short landing run, but safe.
#32
OH
ORIGINAL: scale only 4 me
Can you come out for a couple hours during the week? This weekend sure looks to be a wash
#34
To me the floats look like have wrong shape in front of step when comparing to the drawing of the full size W-29. On the full size plane, the taper starts right at the step.
From what you have, I would move the floats back by 1†to give more floatation volume behind the C/G.
Laddie.
Laddie.
#36
Not all seaplanes have the C/G exactly on the step. Try to fly model with the step behind the C/G.
Other option you have is to move the C/G forward by ½â€.
#37
My Feedback: (158)
FYI,
I'd been running this on rcgroups too and a couple guys there have the same experience with sitting low in the tail, but say it flies fine off calm water.
Weather has been crappy,, maybe this weekend might be decent for the maiden, we'll see.
#38
My Feedback: (158)
Are you friggin kidding me??
http://www.maxfordusa.com/hansabrandenburgw29.aspx
Scoop them up guys,, timing is everything
#39
My Feedback: (158)
Finally flew mine today,, water handling was fine, just a little power to keep it on the floats,, take off was easy, a little pitchy coming off the water,, biggest concern was it had a strong yaw to the left. landing was easy enough with a little power on.
For a small plane it needs a lot of airspace to fly in, I thought it would be good for my local city park pond, but I think I'll have to get used to flying it in tighter before I try it there.
I'll try shimming some more right thrust and see if it flies better next time
#40
My Feedback: (158)
So,
After the last event of the season you can see the float covering came loose again,,, so I decided to strip the covering and add 2" to the rear of the floats,, surgery reveals typical ARF construction,, not enough glue allowing water to enter the floats,, good news is that lack of glue makes surgery easier..
Ready for snow just in case
