Go Back  RCU Forums > RC Airplanes > Seaplanes
Reload this Page >
Beaver cowl
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Beaver cowl
Old 12-24-2012, 05:59 PM
Roger Gray
Default Beaver cowl
OK fellas where can I find a fiberglass cowl for my 72" DH Beaver that I just started from plans purchased from the Air Age plans store. I'm guessing this to be a 60 size plane. The print called for a 40-50 size engine. I hope to install a small GASOLINE engine. The print stated the cowl could be purchased from Northwest Hobby Supply in Oregon, however, they seem to be out of business. FRP Spec.'s has one for a 40 size and a huge one for a 22%. Any ideas would be appreciated.
Old 12-24-2012, 06:54 PM
seaplane
seaplane's Avatar
Default RE: Beaver cowl
I have a Unionville Hobbies 96" Beaver and I purchased a cowl from them at a very reasonable price. They also make a 72" so I assume you could purchase one from them. Unionville does not have a web site and I cannot find their phone number, but maybe someone else with chime in with it. Fiberglass Specialties Inc. makes tons of cowls so you might try them.
Ralph
Old 12-25-2012, 01:15 AM
kwblake
Great Hobbies, here in Canada, is a dealer for Unionville. They may be able to help you. http://www.greathobbies.com/
Old 12-25-2012, 04:47 AM
JimCasey
JimCasey's Avatar
Maybe not what you wanted to hear, but a "Plan B" for you:
I browsed carefully thru the housewares at Walmart and found a 2 quart pitcher that made a good cowl. Measured the depth ( including the right thrust and downthrust offset) and lopped it off. I had to grind away where the handle had been, but this presented a minimal blemish when I positioned that area to be cut away for one of the holes in the cowl. Polyethylene is impact and vibration resistant, so it served well.
In an AMAZING (for me) demonstration of planning and forethought, I selected the covering to match the color of the cowl. Polyethylene does not accept paint well. BTW:This is a Senior Telemaster that I "Beaver-ized"
Less than $5.00.
Old 12-25-2012, 07:39 AM
Warbird Man
My Feedback: (95)
Warbird Man's Avatar
Also try fiberglass specialties. You might find something there.
Old 12-28-2012, 07:12 PM
Roger Gray
Thanks Kevin/Ralph, I emailed Great Hobbies about the 6' Unionville Hobbies FRP cowl and hope to hear from them soon, I'll let you guys know what I learned.
Old 01-13-2013, 07:28 PM
Roger Gray
I've decided to make a plug and make my own fiberglass one. I may post pictures of the process if any interest? Unionville 72" available for only 15.00 or so bucks but the shipping from Canada was more than $60. I have the materials -so- why not!
Old 01-14-2013, 09:22 PM
Bill G
Bill G's Avatar
ORIGINAL: Roger Gray
I've decided to make a plug and make my own fiberglass one. I may post pictures of the process if any interest? Unionville 72'' available for only 15.00 or so bucks but the shipping from Canada was more than $60. I have the materials -so- why not!
That's probably your best bet. I've seen some Beaver cowls that aren't exactly scale, which is as unorthodox as an FW190 with an incorrectly shaped cowl. Nice build you have going there also, and if I were to build a giant scale, the Beaver would be at the top of the list. Currently I have a 24" version, with scratch built floats like yours.
ID:	1840576   Click image for larger version
Old 01-15-2013, 05:18 AM
kwblake
OUCH!!! I guess it works both ways. The shipping cost I mean.
Old 01-27-2013, 05:39 PM
Roger Gray
Well I just built my own. Used the lost core method and I think it looks great!
ID:	1845189   Click image for larger version
ID:	1845190   Click image for larger version
Old 01-27-2013, 07:21 PM
kwblake
110%, with you on that. Looks great. I would guess, this cost a lot less, than the buying and shipping???
Please post some pics when you are finished. Or even some as you get there.
OK Roger this is my second edit. Went back and had another look at your pics. Could you please post some closeups of your float mounts. Wow.
Old 01-27-2013, 08:39 PM
Roger Gray
Kevin I'll probally drop this Beaver Cowl form but will continue the other one on the plane build itself. I'll make a point to post some closeup pics of the gear setup for the floats. They are really easy to do if you have the right materials, a few hand tools, and a small vice. Their fun!
Old 01-28-2013, 05:57 PM
Roger Gray
This will be my last post here. Just wanted to show the cover I put over the engine head. Not scale but it looks OK. I'll primer everything tomorrow. Se ya on the build forum!
ID:	1845339   Click image for larger version
ID:	1845340   Click image for larger version
ID:	1845341   Click image for larger version
Old 01-29-2013, 12:12 AM
dadragon
Roger;that cowl looks very nice,good job.George.
Old 01-30-2013, 04:22 PM
Roger Gray
KWBLAKE-Kevin you'll find the pictures you wanted on the beaver build forum!
