H-9 super cub
RE: H-9 super cub
I havnt yet. Still in the engineering phase. Looks like it will go up on the left side under and behind the dash. I wont be using the front seat, because I will run two recievers and two batteries and the ignition will have to be installed in that area also. Probably beside the tank. Im not much for scale interiors, Id rather have good easy acess to all the stuff. Im still deciding on a servo or manual choke.
RE: H-9 super cub
well the throttle went on the left side like I said, I finnished the fuse, and just about done with the wings. The flap set up is kinda tricky, but seems to work good. The ice is allmost of the lake, so maybe next weekend. I will post some more photos later on this week
#36
RE: H-9 super cub
I glassed the bottom of my floats and it has made quite a difference to how they feel...How much weight are we need to add to the nose roughly ? I have made a Venessa rig and it works great but I have a hard time trusting it , it is so simple .. I am thinking if I need to add weight to the nose I will put some expanding foam in from the step forward .. Just about 1/2 full .. Not the spray can stuff but the mix yourself stuff the boat builders use..The stuff that expands 15 to 1.. If I put a cup full in each float that should do it .. I want to watch the weight .. I have already put a layer of 4.5 oz cloth on the bottom but I only used one coat of epoxy so far...The next layer would not add much weight but the rough surface might be a good thing..
#45
RE: H-9 super cub
I bet it does , I would like to try that on mine .. Keep an eye on your fire wall .. My buddy tore his out on about the 6 0r 7 flight but he was really ripping around .. he just had the DLE 30 on his...I am not sure how much more power the 35 has but I know the 30 is a power house .. I am just running the G26 on mine and I am happy with it.. It has enough for me but then I am an old timing man ..
