Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Float plans?
Reply
Old 01-27-2013, 07:20 AM
stevegauth30
stevegauth30's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Float plans?
Hi all. First off let me say that I have never flown a plane off of water. I am brand new when it comes to floats. I have , however, been flying rc for many years as well as full scale. That being said, I am really wanting to try building a set of floats. I would like to build a set out of foam and glass them. The air frame is a sig 1/6 cub. The fuse length is 41 inches from the back side of the prop to the le of the elevator. If any one knows where to get a set of plans, or has a set to sell, then I would love to hear from you. I would also appreciate any advice, tips or tricks. Thanks in advance for all of your feedback. Steve.
stevegauth30 is offline
Old 01-27-2013, 07:54 AM
kwblake
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Float plans?
You could start off here. http://www.smilesandwags.com/floats.html Jim is very helpful. Also John Buckner might stop by this thread. Also a very helpful member.
kwblake is offline
Old 01-27-2013, 08:05 AM
goirish
goirish's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
bad link I think
goirish is offline
Old 01-27-2013, 08:42 AM
stevegauth30
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, I can't find anything at that link either. I should have said earlier, the reason that I want to build my own rather than just buying a set is that I already have a big pile of foam, a even bigger pile of balsa sheeting, and all of the stuff needed for fiber glassing. Also, I'm more of a builder than a buyer. If I can build it, I would much rather. Thanks again, steve
Old 01-27-2013, 09:22 AM
kwblake
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The link is for Jim Casey's website. Don't know why it doesn't work. It will if you cut and paste it into your browser. Can't explain. He has lots of good info. You could also PM him. Very easy to get along with. I think there may be some plans there somewhere. Not 100% sure though. I am sure he could point you in the right direction. Just went and tried something else. I typed Smiles and Wags RC into my browser and Jims website came up. Hope this helps.
kwblake is offline
Old 01-27-2013, 09:46 AM
TEAMERICA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is a space in there somewhere or something.  But this should work:
TEAMERICA is offline
Old 01-27-2013, 10:08 AM
bikerbc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you measure your plane from the drive washer to the rudder hinge line then multiply by .80 that should give you your length...The step should be about 1/4" to 1/2" in front of the C of G Your floats should extend past the nose about 2 " Some guys like a flat bottom , some like a V bottom...If you can find sombody that has a hot wire set up you can easily make some templates out of formica or plywood ..Just rember that the wire can burn into it if its not hard enough..
bikerbc is offline
Old 01-27-2013, 10:27 AM
stevegauth30
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks a lot guys. I finally got to the site seems like a great place to learn what I need. Thanks again.
Old 01-27-2013, 07:11 PM
kwblake
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: TEAMERICA
Don't u just luv computers. I no I do. AAAAAARRRRRRGGGGGGHHHHHH.
P.S. Great name !!!!!!!!!
kwblake is offline
Old 02-03-2013, 08:51 AM
JimCasey
JimCasey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You guys scared me when the link didn't work.
Glad you found it.
It's http://www.smilesandwags.com/floats.html
I am flattered you find it useful.
JimCasey is offline
Old 02-03-2013, 02:09 PM
TEAMERICA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, Jim, you might want to check some of the links on that page.
I'm having a problem with the Lake Havasu Flyers (http://www.geocities.com/amahsf/)
They may be what is now the Desert Hawks Radio Control Club which can be found at http://www.deserthawksrc.org/
They are the ones that put on the Annual London Bridge Seaplane Classic each year in November.
I didn't check all of the links. Just the ones that are important to me. Thanks for putting up the page.
Old 02-03-2013, 05:18 PM
JimCasey
JimCasey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, I know that time has marched on and some of the links have expired.
Not continually committing html has rendered me less capable to do so than I was.
I need to refresh the dog page, too.
JimCasey is offline
Reply
Display Modes
