Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Blohm & Voss BV-138 Sea Dragon 1:8 scale
Reply
Old 10-30-2013, 10:10 AM
splinterz25
splinterz25's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Blohm & Voss BV-138 Sea Dragon 1:8 scale
Okay this is the BLOHM & VOSS SEEDRACHE' ( SEA DRAGON)
By Gene Falada redesigned by Splinterz25.
BV 138C-1/U1 Seedrache
The Blohm und Voss BV 138 was officially named 'Seedrache' (Sea Dragon) but unofficially it was instead mostly called 'the flying clog'. It was built and used as a long-range maritime reconnaissance flying boat - often flying for hours far out over the sea in search of allied convoys and shipping. Fully loaded it could fly over 4000 kilometers and stay up for 16 hours. This range could be increased even further when using RATO packs (Rocket Assisted Take-offs) or when launched from catapults on board seaplane tenders.
The BV 138C-1 was powered by three Junkers Jumo 205D-1 diesel engines and although they were fuel efficient they made the aircraft very slow and gave it a maximum ceiling of only 5000 m (16400 ft). However, armed with 20mm cannons in two turrets and a 13mm heavy machinegun in an open position as well as an optional MG15 the BV 138 could often take care of itself when attacked. It has for example been known to shoot down a British Blenheim as well as a Catalina flying boat in air-to-air combat. And since the BV 138 could also take a lot of battle damage and keep flying, especially as the diesel fuel rarely ignited when hit by machine gun fire, she was generally well liked by her crews.
Although the BV 138 was able to carry small loads of bombs and depth-charges and thereby do attack missions such as sub-hunting, most operations were pure reconnaissance and surveillance, often working together with the German U-boats. But they were also used for convoy escort, air-sea rescue, personnel and equipment transport or as a few modified ones for mine-sweeping duties.
The BV 138 flying boats were used almost all over Europe and patrolled the North Sea, Skagerrack and Kattegatt, Baltic Sea, Arctic Ocean, Norwegian Sea, Bay of Biscay as well as the Black Sea and the Mediterranean.
Major Production Models
Bv 138A-1 First production version. Service entry in April 1940, 25 built.
Bv 138B-1 Reinforced hull and floats, improved engines and armament. Service entry in Dec 1940, 24 built.
Bv 138C-1 Structural strengthening and improved armament. Service entry in March 1941, 227 built.
Other variants and modifications:
A few Bv 138C-1s were equipped with a large electric degaussing ring and used for minesweeping. Designated Bv 138MS.
Small numbers of Bv 138s were utilized as personnel transports whereby ten fully equipped infantry troops could be carried which actually required no modification of the plane. Luftwaffe's famous special-operations unit, KG 200, used for example one with this purpose.
Most if not all Bv 138s were equipped with catapult points for operation from seaplane tenders and about 20 Bv 138C-1s were equipped with a modified fuel filter to remove possible pollutants when refueling from u-boats. Some C-1s were also equipped with the FuG 200 Hohentwiel or FuG 213 Lichtenstein S radar to easier search out enemy ships and attack submarines.
Of the 227 Bv 138C-1s built, 164 were equipped with two racks for bombs and thereby doubling the offensive payload of the earlier built aircrafts. These later versions were designated Bv 138C-1/U1 although they were mostly still just called Bv 138C-1. Also some Bv 138B-1s are believed to have been modified into U1 versions.
Performance
Max speed 285-300 km/h (177-186 mph)
Ceiling 5000 m (16400 ft)
Range 4000 km (2500 miles)
Dimensions
Wingspan 26.936 m
Length 19.850 m
Height 5.900 m
Crew
5-6 members; Pilot, Navigator, Radio operator, Nose gunner, Rear gunner, Upper rear gunner.
Armament BV 138C-1
1x MG151 20mm cannon in bow turret
1x MG151 20mm cannon in stern turret
1x MG131 13mm machine gun in open position aftward central engine
(optional) 1x MG15 7.9mm machine gun through hatch in starboard side of hull
(Early version) 3x 50kg (110 lbs) bombs on racks beneath starboard wing centre section or
2x 150kg depth charges
(U1 version) 6x 50kg (110 lbs) bombs or
4x 150kg depth charges
This will be a long build and I may end up making a hand cut short kit and glass parts & vac-formed parts if all goes well.
Bruce
splinterz25 is offline
Old 10-30-2013, 02:25 PM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I knew this was a giant scale plane but it's going to take a lumber yard full of wood to build this one HOLLY
The (boat) center section is about 4' wide & over 6' long 22" tall!
the center wing ribs are just over 24"
IT'S A BIGGEN TO SAY THE LEAST
Bruce
ID:	1935037   Click image for larger version
ID:	1935038   Click image for larger version
ID:	1935039   Click image for larger version
ID:	1935040   Click image for larger version
ID:	1935041   Click image for larger version
ID:	1935042   Click image for larger version
ID:	1935043   Click image for larger version
ID:	1935045   Click image for larger version
ID:	1935046   Click image for larger version
Old 10-30-2013, 02:46 PM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
These plans were given to me by a friend who had bought them many years ago and when he heard me mention I was looking for plans for the BV-138 he had a copy made for me he'll be building one also as soon as he gets finished w/ his
DC-3 but I bet he starts sooner than that.
I'll be making changes to the design and making templates as I go it will have removable wing tips & booms and the ELV,STAB will also be removable.
The first thing I changed was how the booms were being made Gene had a
1/4"x 1/4' balsa box frame and balsa formers top & bottom I'm making them all one piece 3/16" thick light ply w/ spruce stringers. This was done because of everything being removable it has to be very strong.
He had called for 1/8" mohogany door skins down the sides of the balsa boxes; but since I've beefed up the frame work I'll skin w/ 1/8 balsa everywhere.
The 3 engines will be Glow fuel OS FS 95-V's.
I've built a scale static display model from Supper Models it gives me a good reference because there's not much in the way of info on this bird out there.
I've found one site on the web there are none intact left in the world just one rusty part of the hull in a museum in Holland.
Here's what I've looked at how the engines will fit and redrawn so far.
Bruce
ID:	1935071   Click image for larger version
ID:	1935072   Click image for larger version
ID:	1935073   Click image for larger version
ID:	1935074   Click image for larger version
ID:	1935075   Click image for larger version
ID:	1935076   Click image for larger version
ID:	1935077   Click image for larger version
ID:	1935079   Click image for larger version
ID:	1935080   Click image for larger version
ID:	1935081   Click image for larger version
Old 10-31-2013, 02:33 AM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's some photos of the BV-138 there aren't very many
ID:	1935223   Click image for larger version
ID:	1935224   Click image for larger version
ID:	1935225   Click image for larger version
ID:	1935226   Click image for larger version
ID:	1935227   Click image for larger version
ID:	1935228   Click image for larger version
ID:	1935229   Click image for larger version
Old 10-31-2013, 03:46 PM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well went to the store today to check out template making supplies and light plywood
and came back w/ a NEW 10" table saw w/ all the plywood and stringers on this build it was time to get one.
Bruce
Old 11-02-2013, 05:07 AM
Bill Diedrich
Bill Diedrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Definitely subscribed to this one.
Did an extensive search for information on the designer,
looks like he has retired is now somewhere around the
82 years old mark if he is still living.
Bill D.
Bill Diedrich is offline
Old 11-04-2013, 03:02 PM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Welcome on board to this build Bill; Gene is still alive some of the guys over on RSCB have been trying to get him to release his 90 sum drawings of mostly unusual aircraft many of the WWII period so far no luck.
I continue gathering materials tools and doing lay out and drawing changes; I have enough 1/8" Baltic birch and just got a sheet of 3/16 birch ply for some of the areas I want to beef up.
I also got a sheet of 1/8" Masonite to make templates out of and because the fuse will be built w/ full formers I bought a sheet 3/4" maple ply to make the 6 foot building jig.
The Fuse (Boat) will rest on the stringers suspended in air while the top is built then flipped to skin the hull.
I should have something to show in a day or so I have a lot going on building the PBY setting up the shop and this build.
Bruce
Old 11-05-2013, 05:13 AM
bogbeagle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.youtube.com/watch?v=RFGemmdHgTI&list=FL4HLk42VM0CCjglQ2KPcYdA&index=48
bogbeagle is offline
Old 11-06-2013, 03:32 AM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for posting the video I had seen it and it was done very well as was the BV-138 build.
Bruce
Old 11-10-2013, 09:10 AM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I continue to redesign the drawings and I've put all of the formers, ribs, and other parts w/ there mods on to one 42" x 120" sheet and there's still more yet to do
But the biggest part is finished.
This way you don't have to cut up the sheets that you'll build on and you can make your parts paper templates all from this one sheet.
Here's some photos of the table saw I bought.
I've also bought a small sanding drum set and a jig saw that I will modifie to make the masionite templates.
Have a look,
Bruce
ID:	1938194   Click image for larger version
ID:	1938195   Click image for larger version
ID:	1938196   Click image for larger version
ID:	1938197   Click image for larger version
ID:	1938198   Click image for larger version
ID:	1938199   Click image for larger version
ID:	1938200   Click image for larger version
ID:	1938202   Click image for larger version
ID:	1938203   Click image for larger version
ID:	1938204   Click image for larger version
Old 11-11-2013, 10:11 AM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okay I made some more changes to the drawings everything looks okay but I'll
have to find the strongest micro servo for the rudders so far the best ones is the
HiTec HS- 225MG .
http://www3.towerhobbies.com/cgi-bin...&I=LXN667&P=SM
If anybody knows of a stronger micro servo I would love to hear about it.
These are the changes to make the tail sections & booms removable
Have a look,
Bruce
ID:	1938468   Click image for larger version
ID:	1938469   Click image for larger version
ID:	1938470   Click image for larger version
Old 11-13-2013, 03:03 AM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okay well the drawing is winding down one more former F-6 and then the wing crutch where the boom meets the wing and I think that will be it but I'll look over everything to be sure.
Here's a quick look at yesterdays progress,
Bruce
ID:	1938846   Click image for larger version
ID:	1938847   Click image for larger version
Old 11-13-2013, 03:37 AM
Bill Diedrich
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a quick question Bruce, do the drawings as originally done allow for
the wing out panels to detach at the booms? With your modification the
aircraft model will now be able to be broken down into 6 separate sections?
(The main hull, 2 boom pods, 2 out wing panels and stabilizer / elevator)
Keep it coming, I look forward to your posting the progress being made.
Bill D.
Old 11-13-2013, 04:21 AM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bill ...YES that's correct it will break into 6 pieces; but you can still build it the way Gene drew it if you want to all the details will remain on the drawings, or you can buy my short kit when it's ready or cut the parts your self for the removable booms both ways will be on the drawings.
Stay tuned to see how this baby goes together and feel free to ask any questions.
Bruce
Old 11-14-2013, 08:51 PM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The drawings are finished next thing is to get them scanned then start
cutting out the templates.
Bruce
Old 11-15-2013, 09:17 AM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okay the drawings are at the printers getting scanned I should have them on a zip drive by days end.
Also the wing tubes came from TNT today one of the 1 1/2" tubes is a bit tight but if I run it over the buffing wheel and polish the ALUM. it should slide nicely these are some BIG tubes.
So once I get the drawings back I will start cutting out the paper templates and fitting them on the 1/8" masionite so I can begin to make the templates.
I also picked up a piece of 1"x 3" x 8' clear Spruce for the boats stringers I had already gotten a piece of 1" x 6" x 6' Spruce for the all of the shorter stringers.
I'm Still gathering supplies and materials there's lots to do yet before any building will start.
But when I do begin I think I'll start building the Booms and the center section of the wing so I can work out the removable Booms and any changes that will need to be made to my templates.
Once the boat section is placed on the building board it will remain there for quite some time because of the size and the amount of work required.
Bruce
ID:	1939423   Click image for larger version
ID:	1939424   Click image for larger version
Old 11-15-2013, 02:43 PM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well being that there's not very much in the way of data on this plane I've at least
found a blown up schematic of the BV-138
If you use the control button on your computer you can enlarge the drawing but you can't read the lettering? it's still a great help I wish I could read it all though.
Bruce
http://www.seawings.co.uk/images/Cut...138cutaway.jpg
Old 11-19-2013, 01:54 PM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In case any body is wondering what happened to me w/ this build I'm still working on it.
I was just taking advantage of the good weather were having and built two fences, shed, retaining wall and a gate in my back yard before the snow gets here; I've just about got it all finished.
Bruce
Old 11-22-2013, 06:12 PM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Martin the guy that gave me the plans has made some nice progress on his build and he sent me some photos via e-Mail and asked me to post them so you guys can see how he's jiging up his fuse/ boat. I will most likely build something similar to hold everything true and square.
Name:	BV-138 hull framing.JPG
ID:	1941338   Click image for larger version
ID:	1941339   Click image for larger version
ID:	1941340   Click image for larger version
ID:	1941341   Click image for larger version
ID:	1941342   Click image for larger version
Name:	Tail gun station.JPG
Old 11-28-2013, 08:41 AM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Happy Thanks Giving Every one!
Old 12-01-2013, 09:39 AM
Avaiojet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WOW!!
Great project! Kudos.
Seaplanes are great!
I'll be watching this build for sure.
Charles
Avaiojet is offline
Old 12-02-2013, 11:30 AM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Welcome on board Charles I'll be slow starting this one but it should be a great build.
Bruce
Old 12-24-2013, 04:07 AM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Merry Christmas Every One & A Happy New Year
Bruce
Name:	2934318-908988-cartoon-illustration-of-santa-claus-is-flying-in-an-airplane-through-the-night-sk.jpg
Old 12-31-2013, 02:56 PM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The progress seen in the photos is my friends he gave me a set of the plans; I'll be starting the former & rib templates for the short kit by the beginning of next week.
Bruce
Old 01-06-2014, 01:12 PM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Alright it took me longer than I thought it would to lay out everything on the Masonite today but I got everything to fit on one sheet.
So tomorrow I'll start cutting & sanding the templates now that I have some new tools it should go much faster than how I was making everything by hand sanding.
Bruce
ID:	1954896   Click image for larger version
ID:	1954897   Click image for larger version
ID:	1954898   Click image for larger version
ID:	1954899   Click image for larger version
ID:	1954900   Click image for larger version
ID:	1954901   Click image for larger version
ID:	1954902   Click image for larger version
ID:	1954904   Click image for larger version
ID:	1954905   Click image for larger version
ID:	1954906   Click image for larger version
Reply
Display Modes
