Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Short S23 Empire buiding thread
Reply
Old 02-13-2014, 05:14 PM
PaulPFW
PaulPFW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Short S23 Empire buiding thread
Hi, Hope you will enjoy this building-thread of the Short S23 Empire flying-boat.
Built by Short's factory in UK during 30ties
Pictures until now:
https://plus.google.com/photos/10778...CMOvp6CC5uS4XA
Scale 1: 16
New postings will follow in this thread.
PaulPFW is offline
Old 02-14-2014, 03:33 PM
PaulPFW
PaulPFW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glued the tail-light
Next job: cover the tail section.
PaulPFW is offline
Old 02-15-2014, 12:55 PM
PaulPFW
PaulPFW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rear bottom end of the fuselage is covered. Happy it needed only a little plaster...........
Next job will be covering the rear top of the fuselage
ID:	1968740   Click image for larger version
ID:	1968741   Click image for larger version
ID:	1968742   Click image for larger version
PaulPFW is offline
Old 02-17-2014, 03:27 PM
PaulPFW
PaulPFW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To-day finished covering the tail section.
Still some sanding to do to get nice round edges.
Hope to start glassing the remaining parts of the fuselage this week.
ID:	1969595   Click image for larger version
ID:	1969596   Click image for larger version
PaulPFW is offline
Old 02-18-2014, 03:36 PM
PaulPFW
PaulPFW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To-day drilled 16 square holes.
Could not finish nr. 4 nacelle as I ran out of 3mm magnets. Used them for the Dynam Catalina.
Ordered new stock at magnets supplier.
Also sanding the tail. Hope to finish the tail within a day or two......
Febr. 20th painted and balanced the props
ID:	1969849   Click image for larger version
ID:	1969850   Click image for larger version
ID:	1969851   Click image for larger version
PaulPFW is offline
Old 02-28-2014, 03:23 PM
PaulPFW
PaulPFW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To-day finished the tailsection and now the fuselage is ready
for glassing.
Also the leading edge on both sides of the wing middle part is finished .
ID:	1973526   Click image for larger version
PaulPFW is offline
Old 03-02-2014, 07:14 AM
PaulPFW
PaulPFW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In case you are interested in a building drawing and/or a laser cut set you can find more information here:
http://www.morganmill.com/RC/Short_E...3_Class-C.html
Regards Paul
PaulPFW is offline
Old 03-05-2014, 03:27 PM
PaulPFW
PaulPFW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tested the nav. lights in both wing-tips.
The aircraft was equipped with one landing-light in the SB wing. She had another (retractable) light built in the nose on port side.
Assembled the engine supports. Glued the parts together.
Next job is glue the engine supports to the wing and test run the engines
ID:	1975396   Click image for larger version
PaulPFW is offline
Old 03-06-2014, 11:52 AM
splinterz25
splinterz25's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks good your moving along at a great pace. WHAT'S THE WING SPAN ON HER?
Bruce
splinterz25 is offline
Old 03-07-2014, 12:43 AM
PaulPFW
PaulPFW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Bruce,
I am following your BV-138 and PBY building threads with great pleasure.
dims of the Short:
The scale is 1/16.5
wingspan of 210cm or 82.6 inch
Regards Paul
PaulPFW is offline
Old 03-07-2014, 04:54 AM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow that's much larger than it looks in the photo; VERY NICE WORK carry sir.
Good luck w/ the rest of your build.
Bruce
Old 03-22-2014, 01:08 AM
PaulPFW
PaulPFW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tested the engines. Nr.3 to be replaced as it does not run very well; bearing problem? No idea and ordered a replacement from HK.
Nr. 4 engine to be checked on a loose magnet.
Started glassing the remaining parts of the hull and continued working on the wing.
Finished nr.3 nacelle
Note: Before taping the balsa nacelle to the spray-can you have to spray the balsa with
a mixture of water and ammonia !!
ID:	1980377   Click image for larger version
ID:	1980378   Click image for larger version
ID:	1980379   Click image for larger version
ID:	1980381   Click image for larger version
ID:	1980382   Click image for larger version
ID:	1980383   Click image for larger version
PaulPFW is offline
Old 03-22-2014, 05:56 AM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LOOKS FANTASTIC - Very slick Paul....I like the way you cut the balsa for the nacelles; I'll have to remember that one for the future on my builds.
Bruce
Old 03-22-2014, 09:24 AM
PaulPFW
PaulPFW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Bruce,
Thanks again for the compliment !!, but the honour goes to my friend Bart who is the brain behind this idea.
After cutting, shaping, glue and sanding the edges I was surprised that both parts fitted perfect.
You can contact Bart about this item; look here:
http://www.rcgroups.com/forums/showthread.php?t=1809276
Regards Paul
PaulPFW is offline
Old 03-25-2014, 10:49 AM
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I talk to Bart on RCGroups all the time I didn't know this was his design he really dose nice work doesn't he.
I'm following there prototype build of the DO 24K HERE
http://www.rcgroups.com/forums/showthread.php?t=2083790
Keep up the great work,
Bruce
Old 03-28-2014, 12:25 PM
PaulPFW
PaulPFW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finished all nacelles.
Engines 1 and 2 are finished, except for the dummy engines.
Engine nr. 3 is replaced for another new engine.
PaulPFW is offline
Old 03-30-2014, 01:44 PM
PaulPFW
PaulPFW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi folks,
Again some progress; finished four engines and cockpit.
ID:	1982833   Click image for larger version
PaulPFW is offline
Old 04-06-2014, 06:19 AM
cf-drg
cf-drg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice job.. nice size too. Here's one at Shuswap float fly a few years ago... Had 4 Enya 80's
cf-drg is offline
Old 04-06-2014, 02:31 PM
PaulPFW
PaulPFW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Darren, beautiful aircraft. She also has flaps, wow ! Taken a look at your gallery: yes you like seaplanes indeed !
Here the results after a busy weekend: have closed the turtle deck and done some paint work. Now the other part of the job...........
ID:	1984671   Click image for larger version
PaulPFW is offline
Old 04-14-2014, 12:21 AM
PaulPFW
PaulPFW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For the time being I am glassing all parts of the aircraft. After this I will post pictures of parts that are finished
A nut of the wing-tip construction disappeared. Had to repair this.
ID:	1986864   Click image for larger version
ID:	1986865   Click image for larger version
ID:	1986866   Click image for larger version
ID:	1986867   Click image for larger version
ID:	1986868   Click image for larger version
ID:	1986869   Click image for larger version
ID:	1986870   Click image for larger version
ID:	1986872   Click image for larger version
PaulPFW is offline
Old 04-15-2014, 01:37 PM
PaulPFW
PaulPFW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paint of both floats finished.
Used 0,1 mm steelwire to create the cross-wiring for the floats.
ID:	1987285   Click image for larger version
PaulPFW is offline
Old 04-17-2014, 05:26 AM
PaulPFW
PaulPFW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi folks, To-day finished glassing the fuselage and some parts of the wing.
Made a construction for rigging the port float with success. Also 0,1 mm steel wire.
Fixed the mast with nav light.
ID:	1987654   Click image for larger version
ID:	1987655   Click image for larger version
ID:	1987656   Click image for larger version
ID:	1987657   Click image for larger version
PaulPFW is offline
Old 04-25-2014, 07:33 AM
PaulPFW
PaulPFW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After lots of hours working for a smooth and acceptable surface of the wing, to-day finally applied the final coating.
PaulPFW is offline
Old 04-26-2014, 11:57 AM
PaulPFW
PaulPFW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just finished the big paint job to-day.
It has been an awfull lot of work, but at the end.... she looks as like the real bird did in the 30ties
ID:	1990150   Click image for larger version
ID:	1990151   Click image for larger version
PaulPFW is offline
Old 04-28-2014, 04:20 AM
itscschie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paul,
fantastic job so far
Greetings,
Christoph
itscschie is offline
Contact Us Archive Advertising Cookie Policy
