Go Back  RCU Forums > RC Airplanes > Seaplanes
Reload this Page >
Top Flite Kittywake
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Top Flite Kittywake
Old 10-24-2016, 06:04 AM
Ram-bro
My Feedback: (101)
Default Top Flite Kittywake
I have done a little research on this kit and it seems that there is not a whole lot of positive feedback on it. I bought this because it was one of my 1st kits back in the day. My plan is to bash it to look like the supermarine s6b. Any advice to make this a better flyer would be appreciated. I am building this while on assignment down south. Should be interesting
Old 10-24-2016, 01:09 PM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
That'd be quite a bash,, first off, I'd keep the float system as light as possible,, maybe use foam, you know,, ya want to keep the wing loading down as much as possible with these small planes
Good luck
Old 10-24-2016, 02:31 PM
Ram-bro
My Feedback: (101)
Itbwill be a simple bash actually. I will keep the single float, round the wing tips, put tge 2 header fairings, enlarge vertical stab, open cockpit, rounded horizontal stabs. I am not looking for any troubles.... trust me on this one.
Old 10-28-2016, 11:31 AM
Ram-bro
My Feedback: (101)
I have decided to do the build. This will be interesting because i am a contrator now. My services are required here in mississippi. So the first thing i had to do was find a hobby shop to get the needed supplies. Now maybe i havent been looking for building supplied lately but it was easier going to your local home depot to get what i needed. The HTown i went too was absolutely no help. I could find glue but not much more. Pitiful. So here are some pics of my portable shop.
Old 10-28-2016, 11:45 AM
Ram-bro
My Feedback: (101)
Indde my homer box are my assorted glues, clamps, pins, tools etc.
Old 10-28-2016, 11:52 AM
Ram-bro
My Feedback: (101)
the wing redraw was to add the elliptical wing tips.
Old 10-28-2016, 11:54 AM
Ram-bro
My Feedback: (101)
the horizontal stab was penciled in. A little larger but doable
Old 10-28-2016, 11:56 AM
Ram-bro
My Feedback: (101)
I[attach=config]2187982[/attach] the vertical stab is where there will be the biggest change. We maintain the same area but the rudder will be above the fuse with an added dorsal fin.
Old 10-28-2016, 12:09 PM
Ram-bro
My Feedback: (101)
the fuse changes are the added dorsal which flows into the cockpit. You will also see the additional chin area and the engine header exhaust covers. I will also add a hatch in the cockpit area and possibly glue the wing to the fuse if i find the hatch eill give me the access i need. The header and chin will be blue foam.
Old 10-30-2016, 11:00 AM
Ram-bro
My Feedback: (101)
The construction continues. One of the difficult thibgs about buildi g in a motel room is finding a flat surface to build on. I went to home depot to buy a ceilibg tile but you have to buy a carton of those to get one. My next choice was a cork covered message board from walmart. $8.00 and we will see how it goes.
ID:	2188245   Click image for larger version
Old 10-30-2016, 11:03 AM
Ram-bro
My Feedback: (101)
The instructions have you start with the center section. Then its onto the outer wibg panels. My building board is not big enough for both panels so it will be one at a time.
ID:	2188247   Click image for larger version
Old 11-05-2016, 03:50 PM
Ram-bro
My Feedback: (101)
Work is proceeding along. Dont want to get done to fast. Starting on tge 2nd wing panel. I normally fly 1/5 scale planes. This is small but i guess that is why i got it.
ID:	2189080   Click image for larger version
Old 11-05-2016, 03:57 PM
Ram-bro
My Feedback: (101)
While visiting the local hobby shop. I was playing with their flight simulator and they had the supermarine s6b on it. Enjoyed being reinspired. I do like the twin fliat setup. I noticed that they wete selling 25 size fiberglass floats also some foam floats for the smaller foamies. Is there a formula for figuring what size floatsone should use?
Old 11-05-2016, 03:58 PM
Ram-bro
My Feedback: (101)
Something else i am consideeibg is goubg electric. Any thoughts on that would also be appreciated.
Old 11-07-2016, 04:04 AM
scale only 4 me
My Feedback: (158)
Typical Float length is about 75% of Fuse length for a twin float set up
Good basic fundimental tips in the Chuck Cunningham artical
http://www.seaplanesupply.com/chuckcu.pdf
good luck
Old 11-07-2016, 04:13 AM
scale only 4 me
My Feedback: (158)
Pluses and Minuses to "EP float planes" for sure
Plus, no glow mess, no dead sticks stranded on the lake,
Minuses, where as you can water proof the electronics somewhat, sometimes when the motor/esc gets dunked, you're dead.
Good video on water proofing here
https://www.youtube.com/watch?v=s4z8QMgTEA4 https://www.youtube.com/watch?v=s4z8QMgTEA4
good luck
Old 11-08-2016, 03:57 PM
Ram-bro
My Feedback: (101)
Great and helpful info. Thsnks
Old 11-11-2016, 08:41 PM
Ram-bro
My Feedback: (101)
I think I will be ordering some 25 size floats from tower since they are ARF and foam. I also took a look at some possible other planes that the Kittywake could be bashed into. How about a macci M C 72
ID:	2189703   Click image for larger version
Old 11-12-2016, 04:06 PM
Ram-bro
My Feedback: (101)
I ordered some gear from Tower since there is not a chance that the LHS will have what I need. I ordered the servoes, rimfire 25 42-40-1000 outrunner brushless and Great Planes Silver Series 45A Brushless ESC 5V/2A BEC speed controller, Origin Wilga-2000 Float Set, cutout the new wing tips. They will add about 5" to the wingspan. from 47 to 52". Glued the 2" pieces for the Horizontal stab and did the ruff cut of the outline.
Old 11-12-2016, 05:36 PM
Ram-bro
My Feedback: (101)
The horizontal stab
