Sea Monster
Sea Monster
The wife, knowing I just started flying seaplanes after 99 (it seems like) years of acro, bought me a Sportsman Aviation Sea Monster ARF kit for Christmas. it appears to be a Sea Master look-alike with a few mods. The kit looks pretty good as ARFs go.
Here are some nice things I noticed about the kit:
-The bottom of the fuselage from the step forward is fiberglass.
-The T-tail is held to the fin by 2 L brackets and 6 bolts.
-The pod mast (whatever) is 3/8 thick with 1/8 ply sides and a 1/8 fiberglass center.
-The hardware package is good with pull-pull cables for the rudder, plastic clevices with metal pins, landing gear, tail wheel bracket, wheels if you want to fly off the turf, fiberglass front and rear pod covers.
Things I didn't like:
-It's nearly all white and I can't see white very well in the air. I am going to have to stick some more color on it.
-The tip floats attach with double stick foam tape. This may be the norm, I don't know.
I am using a Saito .72 for power and I'll report more after I fly it.
RE: Sea Monster
Yes, it does have a V bottom. I'm still a rookie at this, but I do remember the float fly I went to and my Sea Fazer with V-bottom floats landed nicely and the Sea Master there skipped. I attributed it to the fact that I just happened to luck into a good landing.
I also just received a Beast kit. It has a flat bottom center float with tip floats and is a flying wing to boot.
Lots of sea planes, got to have lots of sea planes.
You are going to e-mail me if there is a float fly up your way, aren't you?
RE: Sea Monster
>>You are going to e-mail me if there is a float fly up your way, aren't you? <<
Yep, when I hear of an organized float-fly I will make a lot of noise. Since moving to TN in August, I have not had a chance to fly my floatplanes, and I miss it a bunch. My old club in FL, the Florida Float Flyers, was one of only two floats-only clubs I have been able to identify. (The other is in Lake Havasu city, AZ.) We used to fly every Saturday.
The Knoxville club has organized float flys in the spring and fall, and I am keeping feelers out to the local TN clubs hoping to hear about other splash-ins.
--topic change--
A good float landing:
You set up the airplane about a foot high, trimmed for level flight, and reduce power to about 5 rpm less than it takes to maintain altitude. The airplane floats in ground effect for a while then you notice that the floats are making a wake on the water. The water drag continues to slow the plane down until it drops off the step. THEN reduce power and taxi. (I have only gotten this right about twice).
ALmost as good: you notice the water rudders touching the surface of the water, then the step touches without skipping, leaving one continuous wake for each float.
--topic change--
My Feedback: (58)
TN
RE: Sea Monster
Jim,
I think you going to see some more float flies here at the KCRC site..
I'm a member and part of the pattern crowd but am going to build a seamaster with a few changes, for the next float fly..
Scott Anderson
AMA Cd 227026
Scott Anderson
AMA Cd 227026
RE: Beast wing??......
Here's the URL for the Beast.
[link=http://users.cwnet.com/zdgreg/Mainpage.html]The Beast flying wing float plane[/link]
In addition, the same designer has plane in the Model Airplane News plans catalog for a twin float design called the 2 Ugly.
The Beast has a 48" span and 720 sq. in. area. I have been e-mailing Ron, who sells the kits, and he says a .46 will be at the low end of power. A .61 is in the middle, but most people favor a 4-stroke .91. Since I sometimes fly in brackish water, I am going to use an OS .91FX. I'd rather have it get corroded than a nice 4-stroke .91.
RE: Sea Monster
This is one pretty plane. The "v" bottom and the high elevator are both the improvements that these flying boats needed. It seems that all the good stuff went into Sea Monster. Where can I get a set of plans for this plane? I'm a builder, but not so good that I don't need a set of plans.
How about some pics of the "Beast?
My Feedback: (135)
MA
RE: Sea Monster
Ed,
Those "L" brackets are a great idea. I recognized the weakness of the tail assembly on my Seamaster and fitted the horizontal stab with flying wires extending to the bottom of the fuselage. I had a Saito 56 in mine and it was way underpowered. On wheels it took ALL of of our 300 foot grass runway to get off the ground. I don't think it would have taken off on water. I never got to try because on one take off attempt I forced it off the ground, it stalled miserably and crashed. The tail feathers were the only part of the fuselage that wasn't destroyed.
The Seamaster wing tip floats are attached with Velcro. It makes then easily removable when flying off land.
I think the 72 will be a pefect engine for the Sea Monster!
Have fun
Bob
Have fun
Bob
My Feedback: (7)
RE: Sea Monster
ORIGINAL: Meesh
Bob
Bob
On my Seamaster, I kept losing the tip floats in the water until I ran velgro the full length of the tip float and this solved the problem.
RE: Sea Monster
The pictures sure confirm what a sweet looking plane this one turned out to be. Maybe after building all the kits in the attic, I'll take on this one.
RE: Sea Monster
My Sea monster will be delivered tomorrow, 3/7/05, and i already sawthe model right out of the box. I didn't like the way the outer pontoons are attached either. What do you think would be a better way. I do like the idea of them coming off in a tip dip landing, but I believe good velcro would be a better soultion. Larry
RI
RE: Sea Monster
Hi guys;
I just got my sea monster today. I'm gonna power it with a la 46 that i have lying around. One question though? What did everyone use to water proof the ship. IE wing saddle and such? And If i may what if any problems has anyone encountered?
Thank you in advance
mike
mike
My Feedback: (8)
RE: Sea Monster
I used silicone sealer for the wing saddle...if you already know how to do that let us know, or we'll tell ya how.
I balanced mine a little ahead of the recommended point.
Grease the elev. wire good before you put it in or it'll rust and bind up. Better yet, replace it with a "Goldenrod" or similar.
Mine's been a good and dependable airplane, but some of the covering came off from the top of the fuse. where all the oil spews from the muff. I'd make sure you iron down the covering real good before you fly it...
It flys very well and is really manuverable, and has pretty good manners on the water.
RE: Sea Monster
I've got about 10 flights on my new Sea Monster and I love the stunts. It does all the fancy stuff with ease and settles on the water like a feather. I used thinned epoxy to waterproof the inside. Those outriggers on the wing tips are put on with double sided tape and wouldn't you know it; I lost one of them on the third flight. A quick build and it's OK now. I laid down a bead of Goop around the edges of each and they are solid. A bit os vaseline on the exit holes for the pull-pull cables helps waterproofing, and I also used it on the wing saddle. All in all you'll find it to be a beautiful well designed plane that provides all the fun you want.
Larry
Larry
RI
RE: Sea Monster
Hi Larry;
Thanks for your input. I did a lot of research on these forums and couldn't decide between the monster or master. They both came out with a lot of positive feedback. It came down to my LHS had a monster in stock, plus I really wanted a V hull.
I am sure glad I found these forums, they have been a huge help, and it is really great how much people are willing to take the time to help you out in here. My hat is off to all of you.[8D]
