Go Back  RCU Forums > RC Airplanes > Seaplanes
Reload this Page >
Kyosho J-3 CUB floats
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 09-16-2004, 01:54 PM
lord lucan
lord lucan's Avatar
Default Kyosho J-3 CUB floats
Guys ..
Recently aquired a Kyosho J-3, 70" w/span Cub, new .52FS fitted...i,ve got some rather nondescript floats but thought a bit of advice on the actual best floats for this job wouldnt go amiss....any ideas ..? thanks guys ..
Old 09-16-2004, 09:11 PM
JimCasey
JimCasey's Avatar
Default RE: Kyosho J-3 CUB floats
I was able to find this:
SPECIFICATIONS
Wingspan: 71.7 in (1820 mm)
Wing Area: 760 sq in (49 dm2)
Weight: 5.5 lb (2500 g)
Fuselage Length: 45.3 in (1150 mm)
Requires: 2-stroke .35-.40 cu in (6.0-6.5 cc) or 4-stroke .50 cu in (8 cc) engine, 4-channel radio w/5 servos.
With that Fuselge length, common practice would be to use 36" floats. Normally I recommend styrofoam-core floats. SF or Falcon plastic floats are also quite good.
Built-up wood floats tend to be good for storing water and making for mildew breeding science project.
Old 09-17-2004, 12:48 AM
lord lucan
lord lucan's Avatar
Thanks Jim..
Would these chappies be O.K. ....[:-]...Approx what would they weigh do you recon...?
http://www2.towerhobbies.com/cgi-bin...XJ928&P=0#tech
Old 09-17-2004, 09:00 PM
JimCasey
JimCasey's Avatar
They work well, but all reports are that they are heavy.
I think I would cheat and use the slightly small but better ModelFly floats. In the UK, available from Ripmax. Falcon Trading in the US. A faithful advertiser to this forum, and drawing rave reviews.
RIPMAX Plc. Ripmax Corner
Green Street - Enfield EN3 7SJ
UNITED KINGDOM [email protected]
Tel.: 020 8282 7500
Old 09-25-2004, 07:56 PM
Tsutomu Mabuchi
Tsutomu Mabuchi's Avatar
JimCasey;
That is true.
I have a GP float kit for 40 unbuilt in the box. It is so heavy that I
don't feel like building it. The weight of the box is not the weight of
tha float itself, but can be speculated.
lord lucan;
I would suggest that you add a vertical fin under the rear of the
airplane when you fly cub with floats since two floats give bad
affect to the plane from a lack of vertical area of the tail.
An addition of a fin will make the Cub turn easily in the air.
A J-3 Cub does not have enough vertical area(small vertical
stabilizer) even when without floats.
Tsutomu Mabuchi
