FLOAT SET UP?
My Feedback: (7)
FLOAT SET UP?
Hello all,
I'm ready to try a seaplane!
I've got a set of SeaCommander 48" floats for my 108" WS Piper SuperCub.
Also picked up the SeaCommander mounting system.
Now, how do I figure out how to set the floats up?
How far apart? ( center line to center line )
How high? ( top of float to bottom of plane )
Where to set the step in relation to the CG? ( fore or aft )
Spray Rails? ( yes or no )
What is the best set up for tensioning rods? ( mounts and hardware needed )
Water rudders? ( what works best )
Attaching the mounting system to the plane? ( streamline tubing to what? )
Any other things I should know?
This is turning into a real project!
Thanks for any and all help!
RE: FLOAT SET UP?
Incidence: Most published articles and certainly full scale cubs have the wings 3-4 degrees positive to the top surface of the floats. Some find that with flat-bottom airfoils the bottom surface of the wing can be parallel to the top of the floats. Positive incidence has always worked better for me.
25% of the wingspan is a guideline
The bottom of the prop arc to the plane of the top of the floats should be about 15-20% of prop diameter.
The step goes essentially under the CG (Balance point). Many published articles put the step slightly behind the balance point. One article says it should be under a point at 40% of the MAC (which is the same as the wing chord on a cub). ANother article shows it at 10 degrees behind the balance point....which is about the same place. THese are starting points and some flyers report good results with the step slightly ahead of the balance point. 40% has always worked for me.
Try it without. Be sure to use a plastic prop anyway. DO NOT use a wood prop. Spray will splinter it.
From the upper front strut to the lower rear strut. The float mounting should be rigid.
Search the internet for Brown's seaplane base. There are scads of photos of full-scale cubs so you can model how they do it
ERNST water rudders are scale-like and retractable. Hard to beat. Get the big ones.
You'll have to attach flat plates into the ends of your streamline tubing. They attach to the landing gear mounts of the plane. You'll have to add a hard point to the floor in the aft of the cabin for the rear struts. There was another thread yesterday where a guy attached scale fiberglass floats to a cessna model with streamline tubing. The pictures will help you.
RE: FLOAT SET UP?
Hi, when I bought the floats and spreader kit from Sea Commander, they included drawings and instructions for scale set up and installation for Cubs. They even included photographs of a full scale Cub on floats for documentation. Maybe try and contact them for the info. I know that they just sold the business, but the new owners would still have the info.
Rod
Rod
