Spacing of floats?
TX
Spacing of floats?
Spacing of floats. My floats are to be 15 inches apart. Is this measurement to be taken from the center line of each float or inside to inside?
RE: Spacing of floats?
I'd go with c/l to c/l, although the difference shouldn't matter much. Just make sure they'r absolutely parallel to each other. "Toe-in" will make them plow, and "Toe-out" will make the plane tend to be hard to steer and wobble from float to float.
I set my floats up with the centerlines the same distance from each other as the wheels would be if using conventional gear.
