I need some advice
I need some advice
I mounted a pair of Hacker floats on a Taxi.
I think it turned out to be a bit flimsy according to picture attached.
Should I add another pair of diagonal braces stretching from lower front - rear top of under carriage ?
Or will it be too rigid so things might break instead of flex ?
Thanks for any help
Cheers,
Ikaros
Thanks for any help
Cheers,
Ikaros
My Feedback: (25)
OH
I need some advice
My first gas float plane was a Hobbico AirVista with GP 40 floats mounted in a similar fashion. It flew fine, took off and landed no problem, but the floats weren't as solid as I thought they should be. I now have a SIG SE on floats and am using aluminum mounts like found of a SIG 4Star. Much more rigid mounting system.
So, to answer your question, I would think the more rigid the better. I also thought that allowing for some flex might cushion landings, but it might tend to over flex causing failure.
I need some advice
IN my experience, the more rigid the floats, the better.
I am interested to know about the floats you are using, they look VERY similar to a pair I bought a few years under the 'Obag' name. I used them on a Goldberg Falcon and they worked very well. Sadly, I no longer have the plane, but still have the floats!
Good luck with your float plane, after the first take-off and landing, you'll be hooked!
I need some advice
Thanks for your advice fellows !
So it was written and so it was done !
I mounted two additional diagonal braces of thinner wire, 1mm ,and used turn buckles to keep them tight.
Practical tests will show if it is enough. I will start flying on snow as all lakes are frozen now.
The floats are these: http://www.hacker-model.cz/indexuk.htm
No 1802
Cheers,
Ikaros
No 1802
Cheers,
Ikaros
I need some advice
Linkoping? Don't they build Saabs there? I drove past on a bike afew years ago, in fact my sole experience of Sweden is that one trip. I was in the country for about 6 hours!
My Feedback: (41)
I need some advice
Great! I believe the front lower to rear upper brace you added is the important diagonal, if not the only one required. It resists the force rying to push the float to the rear while in motion, at initial impact, while taking off! I also believe they cannot be too rigid!
I need some advice
The important brace is upper front to lower rear. THis keeps the floats from shifting aft when you hit a wave. Its load is strictly tension, and it can be a very fine wire or cable. I use a piece of approx 1.5mm pushrod wire on my 5kg Senior Telemaster for this, with a clevis on each end. The lower front to upper rear brace is in compression, so it will buckle with very low force.
Also important if you see the floats "dancing" would be an x-brace between the mounting points for the spreader bars on top if the floats. Also only fine wire is needed for this.
FLoat mounting should be rigid.
I need some advice
Hehe Jim,
If I was Usama, then that position would probably guide a TomaHawk to a spot on my lawn, just 5 meters from my window.
Yes David,
SAAB Aircraft is located in Linköping. SAAB Automobile is located in Trollhättan however.
4*60,
To save weight, I have made the diagonal braces quite thin. This means they will not act as struts, they will act as rigging wires only.
In this case, it doesn't make a huge difference, it just causes the stresses to be routed differently in the structure.
I am thinking of also add diagonal bracing between the floats, I think I have seen that on real aircrafts.
Cheers,
Ikaors
PS
Hmm this post should be time-stamped earlier than Jim's last one or maybe they came in at the same time.
DS
Yes David,
4*60,
Cheers,
Ikaors
PS
DS
I need some advice
Hmm, well I have a vague feeling they do. Maybe I read it somewhere in a magazine
The important thing is of cource that they make aircrafts.
Cheers,
Ikaros
Cheers,
Ikaros
I need some advice
Jim and David,
Just of curiosity, how did you work out my location from the position data ?
David was a bit off target, but from a global pow, only by a hair. That makes me even more curious how he worked it out.
By a map, internet service or a GPS with a map display ?
I recorded the position using an old Garmin GPS-38. The calculated un-accuracy (as I like to call it ) was 25 meters at the moment of recording.
Cheers,
Ikaros
Cheers,
Ikaros
I need some advice
Sometimes, I really feel like an idiot!
If I look at Jims map, I see "Mapquest".
A google search and a few clicks reveals this URL:http://www.mapquest.com/maps/latlong.adp.
Cheers,
Ikaros
Cheers,
Ikaros
I need some advice
Well done !
Besides, how come you have an English name, being in Finland ?
You work for a company in GB or US ?
Cheers,
Ikaros
Cheers,
Ikaros
I need some advice
I know why. You fell in love with one of the gorgeous Finnish girls and the only way you could stay with her, was to live in Finland !
Cheers,
Ikaros
PS
I do not by any means indicate there is something wrong with Finland at all, I love Finland (a brother country of Sweden), I'm just curious, that's all, I reccon people with English names are very rare in Finland, thats all.
DS
Cheers,
Ikaros
PS
DS
