Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Show us your Beaver!
Reply
Old 04-23-2007, 05:38 AM
  #51
beaver180
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Show us your Beaver!
Hey there War Birdman... Paul from New Zealand here. Got myself the yellow, white and blue KMP Beaver. Just been checking through some of the threads and thought I'd ask you about some of the mods you may have done to yours.
1, Not a real biggie, but can I paint over the covering? Thinking of making mine a Warbird as the Australian Airforce had one with floats. So I'd like to paint it all green or silver.
2, Don't like the wire land based u/c, do you know of any good scale type remidies here?
3, Did you use the factory fuse servo mounts and control rods? Thinking of running SIG type golden rod down the bottom of the fuse and getting the control surface attachments to the inside ( not showing ).
4, Have you beefed up the fuslage from the tail forward to the former at the rear of the main wing ( just asking as this is my first glass one ), extra expoxy around anything?
5, Did you apply any further strengthning the firewall? Like fully epoxy the gaps on the inside
Oh my elevators have a 1/2 inch gap between them and the fuse, and like wise with the Flaps... did yours too? and have you fixed that?
Sorry for the heap of questions ( don't have anyone here locally that knows )
Thanks, Paul
beaver180 is offline
Old 04-24-2007, 09:25 PM
  #52
Warbird Man
My Feedback: (95)
Warbird Man's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Paul,
I read one can paint over plastic mylar coverings if it is scuffed up real good. I never tried that and don't know how well it will hold up. I chose just to recover the wings to change color and so I could install blind nuts in the wings for the strut attach points and wing tube. I didn't much care for thier mounting methods (small screw into soft balsa as shown in the instructions.)
As far as the landing gear, I think one can use the wire gear and make up some more scale looking fairings over them. I'm only using mine for a few test flights until I get it all dialed in and then permanently installing the floats on it.
I plan on using the servo mounts depending on how it balances out and making up my own push rods.
I would beef up the tail area where the stabilizer mounts to the fuse and the fuselage to the firewall. (You can twist the firewall the way it comes out of the box.) As far as beefing up the fuse between the tail and wing, I don't think is necessary. It's not meant to be an aerobatic airplane.
Check to make sure the formers or secure. On mine they were hot glued in and some were loose right out of the box.
1/2" gap? Mine is about 3/16"on the elevators to fuse and I did add an 1/8" to the flap ends to close up the gap to the fuse.
Overall I think it's a nice plane. It's just that some of the hardware and mounting methods need to be improved and or modified along with the instructions.
Warbird Man is offline
Old 04-24-2007, 09:37 PM
  #53
Warbird Man
My Feedback: (95)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For all you Beaver fans, Check out this web site. Tons of full scale pics and info.
http://www.dhc-2.com/current_cover_page.htm
(It's the current master index for full scale Beavers)
Old 05-08-2007, 12:23 PM
  #54
akflyer
My Feedback: (7)
akflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
KMP Beaver. Vids at www.kmp.ca
G-26 onboard start, lots of goodies.. 22# flys great.
ID:	680284   Click image for larger version
ID:	680285   Click image for larger version
akflyer is offline
Old 05-21-2007, 03:04 PM
  #55
maddog 71
maddog 71's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Scratch built beaver using telemaster 40 wings saito 56 for power setting on great planes 40-60 floats
ID:	688866   Click image for larger version
ID:	688867   Click image for larger version
ID:	688868   Click image for larger version
maddog 71 is offline
Old 05-21-2007, 03:07 PM
  #56
Birddog-RCU
My Feedback: (62)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice!
Birddog-RCU is offline
Old 06-05-2007, 01:28 AM
  #57
Spuetz
Spuetz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Before and After....
short curcuit in the controller... Would you have thought, that fire would be the element that ends the "life" of a float plane?
By the time I had rowed out to the bird in a littly dinghy, it was far gone. Engine and floats were saved (see next post).
ID:	697919   Click image for larger version
Spuetz is offline
Old 06-05-2007, 01:34 AM
  #58
Spuetz
Spuetz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And After After...
So here is the new and improved beaver (HVP modell of Czech Republic)... complete with flaps, position-, anti collision- and landing lights.. [link=http://www.ramoser.de/home_e/varioprop_e/varioprop_e.html]Vario Prop[/link]. Brushless motor (no combustion engine allowed on lakes here in Germany), 5S2P Lipos.
Radial engine done with Williams Bros. cylinders that I found somewhere in the farthest corner of a Sydney hobby shop while being on vacation down under.
landing gear mounted for test flights. Now she's on floats and flies beautifully.
ID:	697921   Click image for larger version
Spuetz is offline
Old 06-05-2007, 08:57 PM
  #59
drewhosick
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quick question for all you beaver fans. Especially those that have dealt with Unionville. Have you found it fairly easy to put that kit together? I was thinking of getting the 8 footer as my third aircraft but it would be my first real build although I've had to repair mine a little and I have a 4 star that was given to me that I have to repair as well. My dream is to have a Beaver on floats and that's what I really want but I'm concerned I just don't have the knowledge to put it together myself as a first kit attempt. Any other suggestions are welcome. KMP is really neat but the price of it really puts it out of my league.
drewhosick is offline
Old 06-05-2007, 09:23 PM
  #60
Closterman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think you have to take a look to my Beaver kit. They are VERY scale and fly great. You can download the building manual on my website to see the knowledge required to build it ! My float kit will be ready in a couple of week.
www.mraerodesign.com
Closterman is offline
Old 06-06-2007, 07:21 AM
  #61
drewhosick
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not to say it isn't a good price for what you get but I just can't afford at my stage to sink 700 dollars into just the kit for a full kit. That's why I was looking at Unionville's
Old 06-06-2007, 02:39 PM
  #62
beaver180
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi there Drew,
My first Beaver was a V-Mar 60-90 sized one.. I found it pretty good looking ( scale like ) and easy to put together. Though they are quite the same as the one KMP or the closterman Beavers, I thought it represent good value.
Once I had built it ( powered really nicely with a Thunder Tiger 91 Four Stroke ) I flew it heaps, actually flew nicer that a trainer, just bigger! I bought a set of great planes 60 sized sport floats later for it.
I decided after a few months of flying it that the nose "looked" too long and I shortened it ( quite easy to do ) by nearly 3 inches. To get the CofG correct all I did was to mount the flight batteries against the engine bulk head and also put in onboard glow system and it's battery well forward too.
ID:	698812   Click image for larger version
Old 06-06-2007, 07:55 PM
  #63
drewhosick
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: p.chatwin
Hi there Drew,
It does look nice. I'll have to keep that in mind.
Old 06-08-2007, 06:43 PM
  #64
racer-RCU
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is my Ikon Nwst kit built dehavilland beaver, it has a 96 in wingspan and is powered by a g-26. this thing is a tank, it survived a crash into a tree where it got lodged between 4 brandhes but its a great plane. I LOVE BEAVERS
racer-RCU is offline
Old 06-09-2007, 09:51 AM
  #65
cf-drg
cf-drg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Racer-RCU nice military Beaver.. A ? what dummy engine did you use?
cf-drg is offline
Old 06-09-2007, 09:53 AM
  #66
racer-RCU
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it was a top flite dummy engine i believe...its been a while but im pretty sure thats what it was
Old 06-10-2007, 03:46 PM
  #67
FHD
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Howdy
This is my beaver from a few years ago,ikon n/west 1/4 scale.
powered by a US 41 flew great till i dumb thumbed it.
this pix was taken at Kenora Ontario float fly.
Hope some day to get another one.
take care
FHD is offline
Old 06-11-2007, 09:22 AM
  #68
Baldeagle
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Drew I built the Unionville beaver several years ago and found it to be pretty easy to build. There is plenty of help here if you have problems. go ahead get your feet wet. The biggest problem would be mounting the floats. The wing is straight <no taper either way> so it is easy. Hope this helps. There is a lot of satisfaction in building your own, instead of buying an ARF. Rich
Baldeagle is offline
Old 06-11-2007, 11:01 AM
  #69
butlern
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just had our first FLoat Fly of 2007 this past weekend... frustrated by a hard starting ZDZ40, I only managed 2 flights on my KMP Beaver. Lots of fun, though!
Thanks to Arobatx for the pics!
ID:	701978   Click image for larger version
ID:	701979   Click image for larger version
ID:	701980   Click image for larger version
ID:	701981   Click image for larger version
ID:	701982   Click image for larger version
butlern is offline
Old 06-12-2007, 04:34 PM
  #70
Goldfinger41
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Noah,
great to see you flying the Beaver. Hope you get the zdz bug worked out, it seems when they sit up for awhile the get tempormental. Im still working on mine , still got a long way to go.
Take Care
Wade
ID:	702801   Click image for larger version
ID:	702802   Click image for larger version
ID:	702803   Click image for larger version
Goldfinger41 is offline
Old 06-12-2007, 04:44 PM
  #71
butlern
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like you've made some progress, Wade. Keep chipping away. You won't be dissapointed. This plane has serious "presence" in the water.
Every time I think I get the ZDZ dialed in, something changes. I just can't believe that a gas motor would be so susceptible to humidity or weather changes (or whatever it is that's causing me grief). I have been hand starting it. Sometimes it pops right off, while othertimes, like this past weekend, it makes me seriously consider buying a Zenoah. I finally have a spinner for it (as of yesterday), so I think I'll have more success get it started and tuned properly when I can crank it with a starter (can't keep a starter centered on the hub without a spinner... near shakes the nose right off the plane).
Now get off line and get back to work on that plane, Wade!
Regards,
Noah
butlern is offline
Old 06-12-2007, 10:02 PM
  #72
beaver180
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi there Wade and Noah,
You guys using gasser? What size props have you got on them? I have a Saito 180 FS mounted into mine and was going to run an 18x6... yours looks 20's at least.
I'll post some pix of my progress soon. mine now has a removable tail for transporting.
Cheers, Paul
Old 06-13-2007, 08:18 AM
  #73
Goldfinger41
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paul,
I am useing 20x8 for break-in, than I will switch to 3-blade 19x10. Removable tail, thats sounds like some serious modifacation.
Good Luck
Wade
Old 06-13-2007, 10:57 AM
  #74
butlern
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paul, I am using the same motor and prop as Wade (2-blade).
Another member in my club flew a 20 lb Decathalon on floats with a Saito 1.80, and it flew pretty well. So, I would guess that it will fly the Beaver, too. I keep promising to weigh mine, but I never seem to remember... and I rarely see the guy in our club that carries around a hanging fish scale in his tool box. Next time I see him (and I have the Beaver) I'll be sure to get that info.
I am intersted in seeing your removable tail modification, too. Post some pictures!
Noah
butlern is offline
Old 06-13-2007, 12:35 PM
  #75
PaulD
My Feedback: (39)
PaulD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just picked up a 12' Beaver built from a Unionville kit. I plan to fly it mainly with floats. The airframe without electronics and engine weighs 26lbs and it is set up for a G62. This sounds to me like I will be short on power by the time I get it done. I figure the AUW will be 40-42 lbs with floats. Some questions for you float guys:
Will the G62 be enough power?
I have talked with another guy flying giant scale on floats and he says APC's are the only prop that stands up to the water spray. Said he ruined a Mejlik in one flight? If I wan to go with a larger engine, APC will not likely have a prop to suit. What are you guys using to stand up to the abuse?
Paul
PaulD is offline
