Convair Sea Dart
RE: Convair Sea Dart
That would be a cool airplane, but I'd be scared of injesting water into the turbine! I believe that the full-scale had this happen once and it suffered explosive results!
Nope. The only one they lost broke up in flight after the pilot hit afterburner too low and too slow, and the resulting acceleration triggered a pilot-induced oscillation. In front of company.
http://home.att.net/~jbaugher1/f7.html
In response to CJTYPED, the Sea Dart article appeared in the July 1989 issue of Model Aviation. The cover had a picture of the model, resting on the water, and the article, starting on Page 94 gave a history and photos of the real Sea Dart. This was a two part article, and I assume the second installment was in the August issue, but I do not have that particular issue, so can’t confirm it.
The author was James Gilgenback, who was also the builder of the model, which used a Dynamax fan unit powered by an OS 77. The model was 1/9th scale, with a weight around 10 pounds. From the article it suggests that the model was only flown off of grass, however, I would believe that the intent was to make water takeoffs. There is a photo of the model taxing on the water under power. Since I do not have the second article, there is no plan or any other information about the model. The July issue does not list a plan set, however, it may have been in the next issue.
Hope this answers some of your questions.
Regards
Bob Thomson
Regards
Bob Thomson
