Floats for 100" Rearwin Speedster
My Feedback: (50)
CA
I know BUSA has a kit for about $140.00, but if I am going to build, I wouldn't mind scratching from plans. Can somebody point me to where I can get a kit or ARC or ARF floats for my plane.
DKjens
DKjens
Sea commander have the floats you require but they will probably cost twice the $140. You can see other threads about what others think of their floats.
www.seacommander.com
Peter
Peter
Both my 90" wing span Cub and my 96" Beaver have 42" floats. The Cub floats are 60 size Great Planes and the Beaver's floats are being made from plans from a Unionville Hobbies kit. I have flown the Cub many times and the combination is great. I haven't finished the beaver yet........Seaplane
Frequent visitors may become annoyed with me about this, bit I have built several links into the Florida Float Flyers website where you can connect to buy floats. Some links even teach you how to make your own. I have gotten reasonably good at making v-bottom foam float cores since BJ is no longer around.
45" floats were mentioned in an earlier message on this thread. I have templates for 45s. I use 'em on my Senior Telemaster. Measure from your rudder post to the prop, and multiply by .75. I don't know why, but that's the universal rule for float length. It works, I accept it. A little bit either way still works. How much does your plane weigh?
