Hobby Lobby ZeeDo floats...comments
My Feedback: (31)
Anyone using these? Overall quality and actual performance on the water appreciated....
Do they have something built into them that will allow an easy attachment of a water rudder???
I assume they have adequate support at the actual float/landing gear attachment point???
http://www.hobby-lobby.com/floats.htm
Thanks....
Thanks....
ZeeDoo floats have been around for a long time.
The ones I have seen were well made. It is prudent to install a drain plug for when water gets inside.
There is No "magic bullet " for mounting water rudders to the floats. Either put a brass tube through the float and run a tiller bar through that to a fabricated water rudder, or I have seen somebody fab an add-on bracket to accept a commercial water rudder. The cleanest way would just be to hang a water rudder from your tailwheel axle and forget about modifiying the floats.
Here's their website.
They look just like the floats at esprit models!!
http://www.espritmodel.com/accesories_floats.html
My Feedback: (31)
The falcon floats will be a little short for what I need, and being the same price as the Espirit floats, I think I'll go with the Glass floats instead of the plastic......thanks for all the replies... In the words of a truly amazing man....
"somewhere southeast of disorder, and between the port of indecision"
My Feedback: (31)
I thought about the Albatross as a floatplane...saw it up close and personal at Oshkosh a few years back...surfboard in it and a fly tying table made out of Mahogany with varnish that looked about 2" deep, amomg other things....
OH
Hobby Lobby did not have their floats at Toledo Expo. I bought a real nice pair of balsa sheeted foam floats from this gentleman. He calls his business Plane Fun. Ralph Smith (737) 671-0134 or email [email protected]. He uses 1/4" aircraft plywood mounts, pinned into the foam with dowels and 1/4" endplates for fastening the water rudder. Sheeted with balsa with mounts attached. Nice quality, the 34" ones are $55.00.
