Hanger9 cub floats
IA
RE: Hanger9 cub floats
I have the 40 size floats. They are well built, but I didn't like the ultracote covering. I stripped them, glassed and painted them. They are installed on the Horizon cub, so the match is perfect, and the water handling was much better than with the Great Planes ARF floats.
I see the 1/4 scale floats are also coming from H9....and are fiberglass.
I'm at work so I don't have the measurements, sorry.
Chad
Chad
MN
sorry I should have clarified that. The new H9 1/4 scale floats, what is the length and what are the struts made of. Tnx, Khelsea
My Feedback: (158)
ORIGINAL: khelsea
http://www.hangar-9.com/Products/Def...ProdId=HAN4580
I'm interested too, might be picking up a 1/4 scale clipped wing myself
SPECIFICATIONS
Length: 47.625 in (1210mm)
Overall width of float assembly: 27.25 in (692mm)
Tip of float to the step: 25.25 in (641mm)
Approximate weight of each float less rudder servo: 30oz
Scale struts weight: 15.4 oz.
Total weight: 75 to 80 oz.
For models weighing: 12 to 18.0 lbs
