scale floats for DC3
Hi I am building 2 scale DC3's and I want to build 1 with floats as per the original wwII model. does anyone have or know where I can find true scale drawingsof these floats? these models will be based on the nick zirolli plans at 140". any help would be greatly appreciated. cheers Johnno
RE: scale floats for DC3
I found that plane too, but have been unable to find out more, just run into dead ends [] thanx for your reply
MI
I want to do the same thing but my problem isn't the floats but the plane itself. I would like a Top Flite size DC-3 that doesnt weigh a ton and fly like a brick. Also, I have seen the Polk's hobby and I am not to fond of the un-scale-ness.
Thanks very much for the input. [in advance]
The picture(s) posted above are of the only Douglas-built prototype XC-47C. The floats were Edo model 78, and they each had a 300 gal. fuel tank in them, as well as two retractable and two non-retractable wheels. The prototype (SN# 42-5671) crashed in Jamaica Bay, New York on Nov. 13, 1943. The cause was listed as gross overload. There WERE, however, other C-47's modified in the flield with floats, so there wasn't just the one, and supposedly there is still an airworthy example somewhere.
I wonder if the one that crashed was taking off from Floyd Bennett Field? Lots of history there, both good and bad.
Here is a link to more pictures of N130Q. It was flying as of the year 2003
http://www.airliners.net/search/phot...nct_entry=true
Another great photo.
http://www.abpic.co.uk/photo/1041964/
Here is the info on the DC-3's current status/ownership. The last change to its registration was made in 2006 so that is a good indication that it is quite possibly still flying.
Serial Number: 11761
Year: 1943
Registrant: Corporation
Street: Po Box 507
City: Greenville
State: ME
Postal: 04441-0507
Country: US
Last Activity: 7/18/2006
Certificate Issue: 1/3/1986
Certification: Experimental / Exhibition
Aircraft Type: Fixed wing multi-engine
Engine Type: Reciprocating
Status Code: Mailed
Airworthiness: 8/28/1990
FAA Aircraft InfoManufacturer: Douglas
Model: DC3-G202A
Category: Land
Engines: 2
Seats: 32
Weight: Class 3
Speed: 158
Min Year: 1937
Max Year: 1955
FAA Engine InfoManufacturer: Wright
Model: R-1820 SER
Horse Power: 1475
Year: 1943
Street: Po Box 507
City: Greenville
State: ME
Postal: 04441-0507
Country: US
Status Code: Mailed
Model: DC3-G202A
Category: Land
Engines: 2
Seats: 32
Weight: Class 3
Speed: 158
Min Year: 1937
Max Year: 1955
Model: R-1820 SER
Horse Power: 1475
Hi again, thank you all for your input, very much appreciated. Is there a web site out there for edo floats? or someone who knows where to get more info from? I am not a puter whizz, and so far my muddling has found brick walls [&:] I really do want to get them right as this floatplane will be built as close to scale as possible, I have a multitude of DC3 / C47 drawings, just need the float plans/drawings cheers
I read in another forum about a guy who was an expert in edo floats from California I think [&:] Does anyone kbow who he is and how to get in touch with him?????????????
I believe Kenmore air are the licensees for EDO floats. EDO is still in business as an aerospace contractor, but not a float builder.
http://www.kenmoreair.com/parts/EDOf...EDOfloats.html
G'day qldviking, please have a look - I've send you an email. Cheers
http://cdn-www.airliners.net/aviatio.../3/0338369.jpg
EDO Model 78-29400 amphibious floats
Length: 42 ft
Beam: 5 ft 8 in
Depth: 5 ft
Weight: 2.234 pounds
Fresh water displacement: 29.400 pounds
Water-tight compartements: 14
Internal fuel tank: 325 gallons
Steering of the hydraulic water rudder system was achieved by use of the brake pedals. The left brake pedal turned the left water rudder out to the left; the right brake pedal turned the right water rudder out to the right; using both brake pedals caused both water rudders to steer out, becoming water brakes.
Length: 42 ft
Beam: 5 ft 8 in
Depth: 5 ft
I've been in N130Q. It was owned by Max Folsom. He gave me my check ride for my float rating back in 91. They are Edo 78's I beleive. I'll be in town this weekend and will see if it's still there. The last time I checked, it was off the floats (2005).
- North
- North
