SIG Sealane
PA
SIG Sealane
Has anyone built or flown a SIG Sealane? I've finished building one over the winter and within the next month I'll be taking it to the lake to fly. The only thing I did different from the plans was to add spray rails. I have a Tower Hobbies 46 PRO engine in it. Are there any bad Characteristics of the plane or is there anything I should know about before the maiden flight. I've been flying float plane for about 3 seasons
RE: SIG Sealane
RS Stout,
Good question. I am in the middle of building one myself and I would like to know the same.
What material did you use for your spray rails and do you have any pics of them? I will be doing the same and I am thinking about using 1/8" lite ply from the left overs from the Fuse side materials. Also, what color scheme did you go with? I am going to be using white/Mild Blue/Dark Blue, but haven't decided on the layout yet. Also, I am planning on glassing the bottom. Laying fiber in the front part on the step and using just the resin to seal the rear.
Good to hear another person is doing one too. I am using a Magnum XLS-46 for mine. Wanted to get an SY GS-45 off Tower, but they changed the ETA date to Late April and I didn't want to wait that long.
Regards,
Curtis
Regards,
Curtis
PA
RE: SIG Sealane
Hi Beau0090 99, I made my spray rails from scrap 1/8 lite ply, at the widest point they are 7/8" wide and 12" long. I epoxied them on, then made a gusset of epoxy and milled fiberglass and applied it to the bottom of the spray rail where it meets the fusalage for strength. I also covered the entire bottom with 2 layers of 1/2 oz. fiberglassand zpoxy. I thought the sheets on the bottom were a little weak. I posted a few picture, I hope they help, if you need more let me know. I fly off a big lake with lots of tree around, so I decided to make the plane yellow to help to see the plane against the trees when landing. I also have a yellow SIG kadet Senior on floats and I love it, it's a big slow flyer but fun to fly never the less.
RE: SIG Sealane
Stout,
Those pictures look great. Have you flown it yet? I think that is how I plan my rails as well. I thought the same about the decking. I was surpriseed that SIG doesn't specifically recommend glassing the bottom. I like your pattern and may replicate it only in white and blue. How did it balance out? I moved my engine forward about .5" and with the glass, I figure it should move the CG forward closer to the desired balance point.
Have fun with it, when I finish mine, I will post a few pics too.
Curtis
Curtis
