Go Back  RCU Forums > RC Airplanes > Seaplanes
Reload this Page >
What size engine on a Sig Kadet Seniorita ?
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 06-23-2003, 02:37 AM
jbfoster
My Feedback: (16)
Default What size engine on a Sig Kadet Seniorita ?
I am going to build a Sig Kadet Seniorita for my first float plane. What size of engine should I use ? Below is the specs on the plane.
Engine: .15-.25 (2-stroke) or .21-.35 (4-stroke)
Wingspan: 63"
Wing Area: 746 sq in
Flying Weight: 3.75 lbs
Wing Loading: 12 oz/sq ft
Fuselage Length: 50"
Airfoil: Flat-Bottom High-Wing
Jim
Old 06-23-2003, 09:41 AM
JimCasey
JimCasey's Avatar
Go with a .20-.25 2-stroke.
If you get good floats you don't need a monster motor to get airborne.
These guys are, like you, in CA, and make good floats.
http://users.cwnet.com/zdgreg/
Other float suppliers are listed in the FLFLFL website.
Lots of pics of Kadet Seniors with floats on the Florida Float Flyers' website. The Seniorita wll be a good floatplane.
Old 06-23-2003, 11:24 AM
seaplane
seaplane's Avatar
The only trouble I've found with the Senorita is when it is a bit windy the plane will tip over easily due to it's large dihedral and it's light weight. You might want to keep the floats spaced apart farther than normal.......Seaplane
Old 06-23-2003, 11:38 AM
JimCasey
JimCasey's Avatar
Ditto what seaplane said, and if you have not yet built the wing, build it flat.
When taxiing, use the ailerons to hold the upwind wing down.
You ARE using ailerons, right?
3-channel floatplanes can be really challenging to taxi.
Old 06-23-2003, 02:39 PM
jbfoster
My Feedback: (16)
Yes I will be building in ailerons. I have not built the kit yet. I have a set of floats, 28" long and the floats are set up 14" apart center to center.
Seaplane, how far apart should I space the floats ?
Thanks for all the info guys.
Jim
Old 06-23-2003, 03:09 PM
JimCasey
JimCasey's Avatar
Rule of thumb is the float spacing is 25% of the wingspan.
If you go much wider than that, (more than 1/3 span, anyway) the plane may become unstable on takeoff, due to large offset drag moments (if one float grabs a little, it will get more leverage and loop you).
Here: read this.
http://www.flyinglindy.homestead.com/skisandfloats.html
Click on the Cunningham article and the pages will blow up so they are legible.
Old 06-23-2003, 10:19 PM
seaplane
seaplane's Avatar
The Seniorita wing I have is 64" so 1/4 of that would be 16" which should be fine. Also Mr. Casey suggested to build the wing flat and I would do just that. You won't need the dihedral if you are adding ailerons and it will be more stable on the water.....Seaplane
Old 06-24-2003, 02:13 PM
Goinstraightup
My Feedback: (26)
Goinstraightup's Avatar
I saw one fly with the OS 26 4C. It was a beautiful combo.
