Question for Jim Casey
Hey Jim,
My employer's firewall has blocked my access to your FAQ sticky.
I'm building a 77" Ziroli Stearman with a fuselage length of 59". Does the 75% rule apply to biplanes the same as monoplanes; therefore resulting in an optimum float length of 45"? Also, how would I figure the distance between the floats since biplanes typically have shorter wingspans than monoplanes per fuselage length.
Harvey
Harvey
RE: Question for Jim Casey
Harvey,
There is nothing specific to biplanes in my website.
75% guideline for float length still applies.
You're right about the float spacing. Go at least as wide as the landing gear spacing. Stearmans still have plenty of wingspan, but it won't hurt to cheat the floats out a bit.
If a typical plane has a wingspan 20% greater than the fuselage length, then 25% span spacing would be 30% of the fuse length. (It's a SWAG, but what else is there? )
Nobody squeezes the floats closer together on a clipped-wing cub!
Since you have a beautiful scale subject, you might research a specific Stearman on floats to match his spacing.
Good luck,
Good luck,
ORIGINAL: JimCasey
Harvey
I hit "google images" for Stearman on floats. Hit a few images:
Here's another
and this one solves the question about float spacing
Or this:
And a Waco from a videogame
The same videogame has a travelair
and a pretty good link with several pics. http://images.google.com/imgres?imgu...%26start%3D324
Here's another
Or this:
I hit "google images" for "Stearman on floats". Hit a few images:
Here's another
Or this:
Here's another
Or this:
Hmmmm... Thanks, Jim, but unfortunately not a single picture or link could be opened. (I'm working with a very narrow bandwidth at this end.) I'll have to wait until I return home.
Harvey
Harvey
