Balancing
MI
Balancing
Hi All,
This is my first attempt at flying off water. I took my E-fite Apprentice and have installed the floats. I'm curious about balancing a plane with floats. On all my land planes I balance just a tad nose heavy. This works fine for land planes, but does it hold true for float planes. Seams to me that a float plane might not like nose heavy because it wants to keep the front of the floats up. What do you guys do.
RE: Balancing
For what it's worth, the wing incidents from the floats should be about 1.5 or 2 degrees up from the floats or the plane won't want to leave the water. If when you try taking off and you see water coming up over the float tips, the incidents between the floats & wing are to close to one another. Add some shims under the forward strut and try it again. You shouldn't have to add much elevator to get off the water. You'll enjoy float flying.
Gerry
Gerry
