Cad plans for floats?
I'm going to make my first set of floats, and I was just wondering if anyone have made a set of plans for a CAD program that I could use as a template. I am new to working with CAD, and I'm trying to teach myself how to work with it. So if anyone could help me out it would serve a dual purpose :-)
TIA
TIA
TN
Here's a simple sheet built, flat bottomed float that is very similar to Mitch Poling's Aquasport from an old Model Aviation mag. I scaled them down for a .15 powered aircraft a few years ago and they worked GREAT! The attached .dxf is scaled down for .049 power at 20.25" long but you can scale them up or down in CAD as needed. You'll have to add the mounting hardware and final details as you see fit but the shape is accurate and will work well.
Good Luck!
Good Luck!
Thank you
Thank you very much for your help.
These are very good templates. My floats are going to be vee bottomed but the side view is the same so....
Looking forward to lifting off my local lake.
