CARF Skygate Hawk in the house !
Old 12-09-2012, 12:41 PM
Colin Gontier
Colin Gontier's Avatar
Default CARF Skygate Hawk in the house !
After owning the fifth scale CARF Hawk (originally scaled down from the Skygate) for a few years I always said the only way it could be better would be to have a bigger one. With all the work involved on the Boomerang side I would never have had time to build the Skygate kit version so how cool is it that CARF have finally got the ARF version available ! Of course it would be sensible as Boomerang sell CARF models to have one to try
My Hawk arrived recently and I haven't had a chance to look at it properly but today I finally had a chance to hang the kit together and boy am I impressed ! Fantastic fit and finish, all the original detail of the Skygate model and very ARF. Nose gear doors are hinged and fitted, main gear doors same thing but not fitted for ease of transport. Everything hinged (scale), control horns in the surfaces. CARF have also taken to blending the seams on the fuselage which is great. Everything looks to be usual CARF style, superbly engineered, very strong and very light. I have weighed everything going in the model and I see no reason why this shouldn't be an under 20kg dry / 25kg wet model with a 180 size turbine. Legend has it that these babies fly better with a bit of weight in them but the great thing is you can have the choice to add weight if you want whereas taking it out isn't quite so easy.
Im hoping to get on to the assembly over the next few weeks but from what I have seen so far it shouldn't take too long. Here are some pics for starters..
ID:	1828242   Click image for larger version
ID:	1828243   Click image for larger version
ID:	1828244   Click image for larger version
Old 12-09-2012, 12:51 PM
Colin Gontier
Default RE: CARF Skygate Hawk in the house !
A few more pics.
Super monster undercarriage - scale leg covers supplied for the main gear as the original Skygate kit.
ID:	1828246   Click image for larger version
ID:	1828247   Click image for larger version
ID:	1828248   Click image for larger version
ID:	1828249   Click image for larger version
Old 12-09-2012, 01:33 PM
basea
Looks great Colin. Very envious. Keep us all posted as the build progresses.
Old 12-09-2012, 02:29 PM
Colin Gontier
Will do Andy - you can fly the Hawk if I can fly the Viper [8D]. Good to see it has flown.
Regards
Colin
Old 12-09-2012, 02:32 PM
basea
Colin - deal!
Old 12-09-2012, 07:26 PM
PaulD
My Feedback: (39)
PaulD's Avatar
So Dean, ordered one yet?
PaulD
Old 12-09-2012, 10:08 PM
Helijet
YES......AND SAME SCHEME TOO!!!!!!!!!!!!!!!!
Wohooooooo!!!!!!!!!!
Old 12-09-2012, 11:00 PM
dubd
dubd's Avatar
Looks really nice! Are the seam lines noticeable?
Old 12-10-2012, 12:59 AM
Colin Gontier
The seam lines have been sanded and colour match sprayed over outside of the mould. You can still see them but as there is so much detail on the model in terms of rivets, panel lines and hatches etc you just don't notice them. Once the model is dirtied up with some weathering I don't see it being a problem.
As the first one shipped my one wasn't done but the nose will have the matt black anti glare painted on. This is done outside of the mould so that gets rid of that seam line so the only one left partially visible from the top is from the back of the cockpit to the fin and thats the one CARF have attended to.
I have ordered touch up paints for all the colours from CARF as if there is anything that needs a touch up I have the matched colours on hand.
I can't wait to start assembling !!!
regards
Colin
Old 12-11-2012, 05:18 AM
Mike Haddox
What is the wing span?
Old 12-11-2012, 06:03 AM
Colin Gontier
Mike , the wingspan is 2510mm and length 3000mm so slightly large than 1/4 scale
Vertical and horizontal stabs both remove very easily for transport and, should you wish to have it the front half of the fus is also removable.
regards
Colin
Old 12-11-2012, 08:58 AM
Mike Haddox
My next project for sure.
Old 12-11-2012, 06:06 PM
Tim Redelman
My Feedback: (36)
Tim Redelman's Avatar
Holy Cow Mike Haddox!!!! Whats next Tom Robertson???
Tim
Hey Mike !
Old 12-20-2012, 01:24 AM
Colin Gontier
Managed to finally get some time to start screwing this together. Of course I had to start with a bit of bling so painted up the undercarriage ! I haven't installed the main leg covers yet so they are still white but you get the idea...
ID:	1832161   Click image for larger version
Old 12-20-2012, 01:28 AM
Colin Gontier
Moved on to the flaps and ailerons next. I could try and make this sound complicated but it was just a case of screw the servos in and make up linkages. The biggest decision was choosing the length of arms for the throws I wanted.
Ive decided to go with super smooth JR8711 all round.
ID:	1832163   Click image for larger version
Old 12-20-2012, 01:30 AM
Colin Gontier
Then on to elevator setup and err screw the servos in again and attach linkages....
ID:	1832165   Click image for larger version
Old 12-20-2012, 03:13 AM
Jetfan20
My Feedback: (21)
Picking mine up today!!!
Old 12-20-2012, 12:42 PM
Colin Gontier
Have you got it then Jetfan? What do you think ?
Old 12-20-2012, 12:48 PM
Colin Gontier
Have been playing with the install this evening. Decided to put the fuel pump, ECU and bubble trap on top of the tank which in turn is velcro strapped to its seat like the smaller Hawk and Tutor. I've done this for easy access to the turbine behind. The whole fuel system and ECU can be taken out with the tank just by releasing the tank straps.
The air and PowerBox system is on the forward tray but still mounted to the rear fus formers so the fus can be split easily if necessary - this is a big aircraft !
ID:	1832315   Click image for larger version
ID:	1832316   Click image for larger version
Old 12-20-2012, 03:53 PM
jetnuno
Looks great Colin
Congratulations
I just think it is a pitty to have a bird like this, painted in the mould..... it really deserves an external paint.
Merry Christmas
Nuno
Old 12-20-2012, 10:51 PM
Ragz
Ragz's Avatar
Super install Colin.  What is the white material you are using for the trays?
Old 12-21-2012, 12:32 AM
Colin Gontier
Thanks Anurag. How is your SG Hawk going ?
The board I have used for the trays is a compressed epoxy board (G10) available in different thicknesses for all sorts of little jobs.
http://www.boomerang-jets.com/index....&cPath=316_318
regards
Colin
Old 12-21-2012, 12:47 AM
bobg
Colin ,great job ,just love that model ,
this model is on my list , looking forward to seeing it ,in the flesh
Robert
Old 12-21-2012, 02:55 AM
Mark H
I have now unpacked mine fully, I have been working on the gears, taking apart and cleaning, and spraying, I have now started on the airframe, I can only agree with Colin , it is just a bolt for bolt construction, as per the CARF Viper, the build the finish the whole package is the best I have seen. Quality like I have never seen before, this is a product all others will need to look at , some folk will say expensive but the amount of work put in by CARF makes up for the price. Fantastic........mine is also in the Swiss scheme and this is also to be seen to be believed. Clean paint work good detail, nice clean lines , inc are all good quality fittings , the flaps, ailerons tail plane fin, all hindges done all horns installed , WOW well done CARF.
Asif (10-21-2020)
Old 12-21-2012, 03:50 AM
bobg
????!!!!""""*** Mark I need one even more now !!!!
