Spitfire Mk XIV 1/5 by fokkeRC
Old 04-12-2014, 05:34 AM
fokke
fokke's Avatar
Default Spitfire Mk XIV 1/5 by fokkeRC
Hello
I start draw one if my favoutite airplane of WW2 the Spitfire
I draw two variants of the model MK XIV one in 1/5 scale and another in 1/4 scale
The first model is in 1/5 scale with 224 sm ( 88.2 Inches)
Engine 55cc gas
and 9-11 kg.
The model is all wood
ID:	1986266   Click image for larger version
ID:	1986267   Click image for larger version
ID:	1986268   Click image for larger version
ID:	1986269   Click image for larger version
ID:	1986270   Click image for larger version
ID:	1986271   Click image for larger version
ID:	1986272   Click image for larger version
ID:	1986274   Click image for larger version
ID:	1986275   Click image for larger version
ID:	1986276   Click image for larger version
Old 04-12-2014, 05:52 AM
fokke
fokke's Avatar
Everything from first post was before one mount ago
today I cut all ribs and details and this is the resolt
Here is the video with the lasercut machine :
https://www.youtube.com/watch?v=RrcSKpdk9Rk&feature=youtu.be
ID:	1986278   Click image for larger version
ID:	1986279   Click image for larger version
ID:	1986280   Click image for larger version
ID:	1986281   Click image for larger version
ID:	1986282   Click image for larger version
Old 04-12-2014, 12:35 PM
Warbird AL
My Feedback: (10)
now that is just way too cool!
Old 04-13-2014, 03:37 AM
fokke
fokke's Avatar
Thank you sir !
OK today I put details together without glue only for test and made several pics
Old 04-13-2014, 11:21 AM
kenair
My Feedback: (10)
kenair's Avatar
Outstanding! thanks for posting your work.
Old 04-13-2014, 11:31 AM
fokke
fokke's Avatar
Thank you very much sir !
Old 04-13-2014, 09:17 PM
Ram-bro
My Feedback: (101)
do you have a paint scheme picked out? You have all the fun toys
Old 04-13-2014, 09:27 PM
fokke
fokke's Avatar
I have not chosen yet, but have several great paint scheme
ID:	1986850   Click image for larger version
ID:	1986851   Click image for larger version
ID:	1986852   Click image for larger version
ID:	1986853   Click image for larger version
ID:	1986854   Click image for larger version
ID:	1986855   Click image for larger version
Name:	Spitfire Mk XIVc SM832.jpg
ID:	1986856   Click image for larger version
Old 04-13-2014, 09:49 PM
Ram-bro
My Feedback: (101)
are you considering a clipped wing version?
Old 04-13-2014, 09:54 PM
fokke
fokke's Avatar
Yes it is possible to do a short version of the wings. It is very easy to do so by changing the detail of the wingtip
Old 04-14-2014, 05:03 AM
ticketec
Looks great fokke! But not more dora?
thanks
dave
Old 04-14-2014, 05:42 AM
fokke
fokke's Avatar
Dave, off course I work on Dora, this Spity is between the other projects.
Today I send all parts of Spitfire of my friient Ivan , he will assemble the model , I just rest of Dora
Today I made the nose of Spity , will be composite ( the nose)
Old 04-14-2014, 04:46 PM
flyingpiggy
Hi Fokke
Are you going to make your design available to the modelling community? if so then what are the chances of you designing a second set of rear fuselage formers to model the low back version of this spitfire {and perhaps a canopy design}. There are precious few designs out there for a griffon engine low back spit.
Regards
Dave Read
Spitfire brother #14
Old 04-14-2014, 07:12 PM
Chris Nicastro
Chris Nicastro's Avatar
Awesome! My favorite Spitfire Mk 14!
+1 on the bubble canopy option Mk 22(or 24?)
Old 04-14-2014, 09:27 PM
fokke
fokke's Avatar
Ha , this is great idea Dave Read !!! I can make 3 sets of the airplane , with short wings , with fuselage and diferent canopy (your idea) and the main set wich I made .
What you mean with "
Are you going to make your design available to the modelling community?"" ?
Old 04-14-2014, 10:01 PM
ticketec
If you need a friend for the Dora, you let me know you can never have too many Dora's! I keep looking and thinking about your Emil too. my favorite version of the 109.
Good luck with the Spitty, looks like you already have plenty of fans queuing up to buy one
Dave
Old 04-14-2014, 10:11 PM
fokke
fokke's Avatar
Now I made change of the wings :
ID:	1987144   Click image for larger version
ID:	1987145   Click image for larger version
Old 04-14-2014, 10:28 PM
flyingpiggy
Hi Fokke
Sorry, I didn't look closely enough to your posts to see that you run an on line store {too busy ogling your lovely cad work}
So I guess the question is when is your spit available and what format i.e plans+ laser cut parts or largely pre-built?
I aquired a set of moulds to produce Mk 9 {& Mk16 early} fuz+cowl+canopy+radiators&other lumpy bumpy bits at 1\6 scale. These parts are accompanied by a set of wing & tail drawings. This looks very similar to the Mick Reeves product - suspiciously similar!!
I have only produced one model so far, powered by YS 140L & fitted with home made retracts. The 140 is an awesome power plant - when it goes!!!
I was looking at some photos of the plane during construction and finishing. My son looked sooo young then - he's now at university!
Regards
Dave Read
Old 04-14-2014, 10:34 PM
Chris Nicastro
Hi Fokke,
Which CAD software are you using to design your models?
Are you also drawing the skin of the model or just the structure?
Old 04-14-2014, 11:24 PM
fokke
fokke's Avatar
Chirs, I work only with CorellDraw 13 , what you mean with "" skin of the model"" , if you talk about the cover with balsa NO I can't make it because I work only in 2D
Hi Dave
I start work with CorelDraw because I needed to make plywood ribs of my project BF-109 E4 . There I made wood ribs of wings and several ribs for the composite fuselage. I like the result so I wanted to try to draw something different and some entirely wooden model. I like this version of Spitfire , because the nose is longer , the wings are different and the vertical stab is pointed. I dont know Mike R kiit , I don't have it .
I had used many factory plans and my experience with BF-109 model to start build this model only for fun ( I build composite models ) I wanted to improve my experience to work with CorellDraw. Now I can see my mistakes and correct them Now I work on 1/5 scale FW-190 D 9-13 , so I nead to learn the Corell for the best results
Here you can see my old work with BF-109 :
http://www.rcuniverse.com/forum/rc-w...-1-5-a-42.html
http://www.rcuniverse.com/forum/rc-w...-1-5-a-44.html
http://www.rcuniverse.com/forum/rc-w...l#post11431950
Here you can see the all processe of my Spity work :
https://www.facebook.com/fokkerc.cha...1357831&type=1
Cheers guys
Old 04-14-2014, 11:50 PM
fokke
fokke's Avatar
Dave
Dave , always nead friends for Dora, she is my old love. Before 17 years ago I start with composites with D9 in 1/6 scale You can see my beginner work , the model never flown
http://fokkerc.flugmodel.net/fw190.html
Old 04-15-2014, 02:29 AM
fokke
fokke's Avatar
[COLOR=#000000]Dave Read, this the method wich I use to make my plans .
I have 2.69 GB factory plans of each versions of Spitfire, so I make my plans under this factory plans
As we can see , the differens between XIV and XIVe is the the rudder to , so if I want to make it I shood change and rudder
Old 04-15-2014, 06:25 AM
fokke
fokke's Avatar
OK I made several changes on main plans :
Old 04-15-2014, 06:48 AM
Chris Nicastro
Ok I see. That makes things a little faster to create if you have the factory drawings as well.
Did you buy the factory drawings from a guy in Australia on Ebay? A few years ago I bought a disc with a lot of FW 190 factory drawings, very helpful.
Old 04-15-2014, 07:43 AM
fokke
fokke's Avatar
No Chris , the most plans are gift for my 38 birthday , and I was so happy , some I bought from internet but don't know the guy
