Fei Bao Jets Dolphin build thread by RCISFUN
Old 06-23-2014, 06:42 PM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Default Fei Bao Jets Dolphin build thread by RCISFUN
This will be my build thread for the new Fei Bao Sport jet, the Dolphin
In this thread I will attempt to cover the building sequence and the design of internal mounting components that I made during the assembly of this great model.
Additionally I have been asked by the factory to write the manual.
I starting working on this model in the beginning of May for a couple of evenings a week and have been photo documenting my work as I proceeded. I designed all of the internal mounting parts in AutoCAD and have forwarded to the factory for inclusion into the production model.
Drawings will include fuel tank mountings, two nose mounted battery boxes, UAT mounting, mounting plates for servo connections and a balancing fixture.
I will start off with photos of the completed model, specification of the various parts and then start posting my build sequence.
The model has just been test flow by three competitive pattern pilots, Jim Hiller, Lewis Patton and Joe Stek. The feedback from these three gentlemen was unanimous, FB Jets has a winner on their hands.
The basic specifications are as follows:
Length: 104 1/3" (2650MM)
Wingspan: 91 3/4" (2330MM)
Dry Weight w/all components: 35 Lbs (15.9 Kg)
Power: 32 Lbs to 40 Lbs (140 N to 180 N) Jet Central Rhino used in prototype
Fuel Capacity: 155 oz (4.6L) (Prototype)
Main Wheel Diameter: 4.3” (109 mm)
Main Strut Length: 7.5” (190.5 mm)
Pipe Length: 37” (940 mm)
Pipe Diameter: 3 ½” (89 mm)
Bell Mouth Length: 2.75” (70 mm)
Equipment Used:
Elevators (2) Hi-Tec HS-7955TG
Ailerons (2) Hi-Tec HS-5625
Rudder Hi-Tec HS-7955TG
Flaps (2) Hi-Tec HS-7955TG
Steering Hi-Tec HS-645MG
Door Valve: Jet Central Dual Action
Landing Gear Valve : Jet Central Dual Action
Brake Valve: Jet Central Single Action
Door Sequencer: Jet Central
ECU Battery: 5000 mAh LiPo 2 cell Hard Pack
Receiver Battery: 5000 mAh LiPo 2 cell Hard Pack regulated to 6V w/Liner voltage regulator
ID:	2008235   Click image for larger version
Old 06-23-2014, 06:51 PM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Attached is the component weight information
File Type: pdf
Old 06-23-2014, 06:56 PM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Below are some photos of the internal structures, the wing, stab and rudder using a bore scope camera
FB used liberal amounts of CF for reinforcement
Name:	inside dolphin rudder 1.JPG
ID:	2008238   Click image for larger version
Name:	inside dolphin stab 3.JPG
ID:	2008239   Click image for larger version
Name:	inside dolphin stab 4.JPG
ID:	2008240   Click image for larger version
Name:	inside dolphin stab left 1.JPG
ID:	2008241   Click image for larger version
Name:	inside dolphin stab left 2.JPG
ID:	2008242   Click image for larger version
Name:	inside dolphin wing 1.JPG
ID:	2008243   Click image for larger version
Name:	inside dolphin wing 2.JPG
ID:	2008244   Click image for larger version
Name:	inside dolphin wing 3.JPG
Name:	inside dolphin wing 4.JPG
ID:	2008246   Click image for larger version
Name:	inside dolphin wing 5.JPG
ID:	2008247   Click image for larger version
Name:	inside dolphin wing 6.JPG
ID:	2008248   Click image for larger version
Name:	inside dolphin wing 7.JPG
ID:	2008249   Click image for larger version
Name:	inside dolphin wing 8.JPG
ID:	2008250   Click image for larger version
Name:	inside dolphin wing 9.JPG
ID:	2008251   Click image for larger version
Name:	inside dolphin wing 10.JPG
ID:	2008252   Click image for larger version
Name:	inside dolphin wing 11.JPG
Name:	inside dolphin wing 12.JPG
ID:	2008254   Click image for larger version
Name:	inside dolphin wing 13.JPG
ID:	2008255   Click image for larger version
Name:	inside dolphin wing 14.JPG
ID:	2008256   Click image for larger version
Name:	inside dolphin wing 15.JPG
ID:	2008257   Click image for larger version
Name:	inside dolphin wing 16.JPG
ID:	2008258   Click image for larger version
Name:	inside dolphin wing 17.JPG
ID:	2008259   Click image for larger version
Name:	inside dolphin wing.JPG
ID:	2008260   Click image for larger version
Name:	inside dolphin rear fuse 4.JPG
ID:	2008265   Click image for larger version
Name:	Rear Fin Mount.JPG
ID:	2008266   Click image for larger version
Name:	Front Fin Mount.JPG
Old 06-23-2014, 07:18 PM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Landing Gear details
Note: Make sure to remove wheel axial's and use a fine grit sand paper with the axial chucked in a power drill to spin and remove a slight amount of material and then apply grease, I noticed that the wheel bushing was galling with the axial. Also make sure to file a grove in the axial where the set screw make contact, the same hold true for the nose wheel pin, file two groves for the two set screws.
ID:	2008280   Click image for larger version
ID:	2008281   Click image for larger version
ID:	2008282   Click image for larger version
ID:	2008283   Click image for larger version
ID:	2008284   Click image for larger version
ID:	2008285   Click image for larger version
ID:	2008286   Click image for larger version
ID:	2008288   Click image for larger version
ID:	2008289   Click image for larger version
ID:	2008290   Click image for larger version
ID:	2008291   Click image for larger version
ID:	2008292   Click image for larger version
ID:	2008293   Click image for larger version
ID:	2008294   Click image for larger version
Old 06-23-2014, 10:41 PM
fbjets
Rich, very detail, I took two pictures to post on our domestic forum.
Catherine
FeiBao Jet Models
Old 06-24-2014, 01:48 AM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Thank you Catherine, I will continue posting the build photos and comments as time permits.
Did you get my e-mail on the fuel tanks?
Old 06-24-2014, 02:47 AM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Fuel System:
The majority of effort in this prototype build was coming up with a method to secure the fuel tanks and to get extra fuel capacity.
There were three fuel tanks supplied with the prototype, they consisted of two saddle tanks and one main tank, the shape of the main tank in my opinion is not conducive to an aerobatic sport jet as the depth is shorter than the height, this makes for bad clunk geometry.
Each saddle tank volume is 37 oz (1.1L) and the main tank is 47 oz (1.4 L) for a combined volume of 121 oz (3.6L).
For an airframe of this thrust class I felt that it not enough fuel so I added an extra 34 oz (1L) tank and positioned it below the main tank. It was able to slide underneath the inlet ducting, I made a shelf above the extra tank for the main tank to sit on. This brought the total volume up to 155.5 oz (4.6L).
For the test flights the timer on the transmitter was set for six minutes, most of the test flights were conducted at around half throttle, after landing and taxiing back there was one full saddle tank and the main tank was full, i.e. 84 oz (2.5 L) of remaining fuel.
Note: A external taxi tank was used for start up and taxing out to position.
The brass fuel line and the "rubber" clunk hose supplied with the prototype were not used as they were too small for this thrust class, they are shown below for reference only.
The stopper plates were drilled out to accept 3/16" (5mm) brass tube. All external fuel and vent hose used was large diameter Tygon tubing.
The tanks were supplied with aluminum ring fittings for the rubber tank stoppers, they were prepared to be cemented to the tanks by drilling 1/16" (1.5 mm) holes around the shoulder perimeter to allow the Hysol to penetrate and add extra cementing area.
The tank mounting I designed for these particular tanks is shown below, the saddle tanks bolt into the fuselage and the main tank is held into position by a bracket.
The clunk set-up for the saddle tanks and the main tank is shown below, as you can see the travel for the main tank is limited by the short length of hose connected to the clunk and the saddle tank geometry is not an issue.
The inner connection of the tanks are in series, i.e. the extra 1L tank is connected to the outside vent and feeds the left saddle tank. The left saddle tank in turn feeds the right saddle tank, and the right saddle tank feeds the main tank. Because of the large diameter tubing used I had no issues during filling, i.e the tanks did not balloon up due to restrictive venting.
I believe that the factory has since come up with a different set of tanks, I am waiting for confirmation from Catherine.
ID:	2008328   Click image for larger version
ID:	2008329   Click image for larger version
ID:	2008330   Click image for larger version
ID:	2008331   Click image for larger version
ID:	2008332   Click image for larger version
ID:	2008333   Click image for larger version
ID:	2008334   Click image for larger version
ID:	2008336   Click image for larger version
ID:	2008337   Click image for larger version
ID:	2008338   Click image for larger version
ID:	2008339   Click image for larger version
ID:	2008340   Click image for larger version
ID:	2008341   Click image for larger version
ID:	2008342   Click image for larger version
ID:	2008344   Click image for larger version
ID:	2008345   Click image for larger version
ID:	2008346   Click image for larger version
ID:	2008347   Click image for larger version
ID:	2008350   Click image for larger version
ID:	2008351   Click image for larger version
ID:	2008352   Click image for larger version
ID:	2008354   Click image for larger version
ID:	2008355   Click image for larger version
ID:	2008356   Click image for larger version
ID:	2008357   Click image for larger version
ID:	2008358   Click image for larger version
ID:	2008359   Click image for larger version
ID:	2008360   Click image for larger version
ID:	2008362   Click image for larger version
ID:	2008363   Click image for larger version
ID:	2008364   Click image for larger version
Old 06-24-2014, 03:16 AM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
UAT
The UAT used was the BVM style, I designed a UAT holder that I have used in my other models.
I test my UAT in a bowl of water and pump it up to around 30 psi (2 bar) with my air compressor.
That's all for now, until later!
ID:	2008366   Click image for larger version
ID:	2008367   Click image for larger version
ID:	2008368   Click image for larger version
ID:	2008369   Click image for larger version
ID:	2008370   Click image for larger version
ID:	2008371   Click image for larger version
ID:	2008372   Click image for larger version
ID:	2008387   Click image for larger version
ID:	2008389   Click image for larger version
ID:	2008390   Click image for larger version
ID:	2008391   Click image for larger version
ID:	2008392   Click image for larger version
ID:	2008393   Click image for larger version
Old 06-24-2014, 03:50 AM
lxfly
lxfly's Avatar
Hi Rich,
As I like the Futura, I also might like this Dolphin, but I do not like a so complex fuelsystem: Would it not be possible to omit the air conducts and just use one tank like oll these Futuras and Vipers do?
Old 06-24-2014, 05:00 PM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Originally Posted by lxfly
Hi Rich,
As I like the Futura, I also might like this Dolphin, but I do not like a so complex fuel system: Would it not be possible to omit the air conducts and just use one tank like oll these Futuras and Vipers do?
I would not recommend cutting the inlet ducting, in looking at it you would not gain much.
Old 06-25-2014, 03:41 AM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Battery Box:
In order to get the CG on the Dolphin it was obvious that weight was going to be needed up front in the nose.
As I was presented with a clean slate with the prototype it was decided to create two battery boxes and to make them as long as possible to allow the batteries to be shifted to make CG corrections. It was decided that the best live weight would be hard cased 5000 mAh 2 Cell LiPo's used for RC cars. I used one for the ECU battery and the other with a linear regulator to run the receiver. You don't have to worry about charging that during a flying session! As it worked out this was the perfect nose weight as the CG came out spot on with the batteries slid fully forward, I used pieces of high density white foam as the "keeper" to hold the batteries into the box, these can be easily removed (not too easy as to let the battery slide during flight) to allow the batteries to be removed for charging.
ID:	2008646   Click image for larger version
ID:	2008647   Click image for larger version
ID:	2008648   Click image for larger version
ID:	2008649   Click image for larger version
ID:	2008650   Click image for larger version
ID:	2008651   Click image for larger version
ID:	2008652   Click image for larger version
ID:	2008654   Click image for larger version
ID:	2008655   Click image for larger version
ID:	2008656   Click image for larger version
ID:	2008657   Click image for larger version
ID:	2008658   Click image for larger version
Old 06-25-2014, 09:54 AM
kyates
kyates's Avatar
Any flight video yet Rich. Louis said it fly's very good
Old 06-25-2014, 10:02 AM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Hey Keith, absolutely
Check out this thread, post # 28:
http://www.rcuniverse.com/forum/rc-j...t-event-2.html
I knew that Louis liked the Dolphin when we had to pry the "Futaba" transmitter out of his hands!
Old 06-25-2014, 07:40 PM
kyates
kyates's Avatar
Thanks Rich looks like a good flying jet in the video
Old 06-26-2014, 09:01 AM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Thanks Keith,
I just was informed about another surprise... it looks like there might be a New Jet Central Turbine offering that will be installed in the Dolphin for KY Jets, more details to follow.
Sorry that I wasn't able to post more of the building sequence, I was tied up a bit.
Old 06-26-2014, 03:21 PM
causeitflies
causeitflies's Avatar
I sent Catherine a PM a few days ago for some info but haven't heard back yet.
Old 06-26-2014, 05:40 PM
jws_aces
My Feedback: (33)
jws_aces's Avatar
contact her by emial. She has communicated with me a lot about one of the jets she is going to have a Ky jets. Email is in her sig..
Old 07-01-2014, 06:44 PM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Been busy getting ready for JOK so I haven't had time to post much. I did manage to work on the main gear door retract cylinder geometry which didn't seem to be able to close the doors once the air speed was up.
The factory location had the cylinder inside of the wheel well
I cut out the original mount and moved the cylinders inboard, I cut new mounts and hysoled them in.
The cross brace needed to be repositioned
Extra cross braces were hysoled in to stiffen the new cylinder mounts.
New cylinder mounts
I guess we will find out if this takes care of the main door issue at JOK
ID:	2010484   Click image for larger version
ID:	2010485   Click image for larger version
ID:	2010486   Click image for larger version
Name:	cylinder mounts.JPG
Old 07-02-2014, 02:38 AM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
The attachment position of the door cylinder to the door hinge is now moved to create a different mechanical advantage.
Before
After
New cylinder mounting parts after cutting
ID:	2010546   Click image for larger version
ID:	2010547   Click image for larger version
ID:	2010554   Click image for larger version
Old 07-02-2014, 03:05 AM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
On the maiden flight the right retract did not come down resulting in a scrapped wing tip, of course the gear worked every time on the ground during testing
During the post flight inspection it was discovered that there was an interference on the strut at the wing / fuselage junction where the rib was cut out, it was only about a 1/16" (1.5mm) interference, but is was enough to not let the retract disengage. It was a simple fix to gring away a bit of the rib.
For the repair a carbon fiber plate was attached to the affected area on the wing tip.
ID:	2010556   Click image for larger version
Old 07-02-2014, 09:20 AM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
I was able to test the door operation (on the bench) during my lunch today, and they are functioning perfectly, next week they will be tested in the air!
Old 07-13-2014, 06:55 PM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
After the test flying the new gear door cylinder configuration at Kentucky Jets it was decided to remove the main doors, I believe that the Factory is going to re configure the model to remove the main gear doors on the production models.
Old 07-13-2014, 06:56 PM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Congratulations to Mark Palmer and Keith Yates who now are the proud owners of the #2 & #3 Dolphin in the US.
Mark purchased the display model at Kentucky Jets and Keith had the winning bid on the auction model.
Old 07-13-2014, 08:11 PM
jet time
My Feedback: (75)
jet time's Avatar
I was really impressed at KJ with the Dolphin. It really flew great at ALL speeds. I'm sold! ;-)
Old 07-16-2014, 07:38 PM
causeitflies
I finally got the Dolphin unpacked and sorted out and plan on hitting it hard the next few days.
Rich, send me your final CG and throws when you get a chance. I hope to have it flying for Michigan.
I'm going to try to make the gear doors work too. The easy fix may be two cylinders per door but I'm going to try something else first.
The hardest part of of finishing this plane will be finding a pilot for it
