Strato's SU-76i Build
Old 09-20-2014, 11:58 PM
Strato50
Strato50's Avatar
Default Strato's SU-76i Build
Hey all,
Airbrushler posting his SG-122 build here made me want to transfer over my build thread as well
This is a SU-76i from kit PanzerParts found here http://www.panzerparts.com/product_i...3-HL-1-16.html
It's economical and pretty easy to do. I'm really enjoying this kit.
The casemate basically sits right ontop of the Panzer III upper hull. In this kit you have to remove the entire front armor plate including the ball machine gun and drivers view port. The kit provides replacement plates in cast metal that mate up with the gun shield. I opened up the inner hull underneath the casemate just to give me more room to work with.
This tank will have elevation, recoil and barrel flash, Taigen steel gears and a track tensioner.
Old 09-20-2014, 11:59 PM
Strato50
Strato50's Avatar
Added the flashing that was around the base of the casemate. It came partially molded in resin but on the actual vehicles it extended past the base, so I sanded the molded bits off and made my own out of aluminium.
Used my trusty drywall gap filler putty to fill in a few places, and add a weld seam line on the rear. This stuff doesn't have much strength at all but it's very easy to sand and shape for moderate fill jobs... add some CA glue after it's cured and it get's pretty tough.
Old 09-21-2014, 12:00 AM
Strato50
Strato50's Avatar
Progress!
Got my hinges in the mail.. not bad, more than enough hinges for this tank for about $6 inc. shipping. Yay eBay.
I also ordered a pin vise / micro hand-drill after watching Dean do all sorts of fine details that my full sized power drill isn't really meant for.. once that arrives I'll drill out the hinges and glue in some bolt or rivet heads too. I simply don't trust the hinges just being glued
...and now the painting begins. Again Krylon Ultra-Flat camo green from Crappy Tire. Love this stuff.
I bought a can of Krylon Clear Coat, Satin finish to see how that works.. Don't really need it for this tank but if it seals in details like rust, mud and whatever extra decals go on then I'll use it more also.
Old 09-21-2014, 12:02 AM
Strato50
Strato50's Avatar
Hurrah for new parts! Got a nice big box in the mail today including a bunch of new gearboxes and idler-tensioners from rctank.de (one set for my new-ish Stug) I highly recommend rctank.de and Dominique over in Germany. Simply flawless service and communication & excellent parts to choose from.
Gearboxes are steel with final drive ball bearings. I have this same set in my Chi-Nu Kai, T-34 and Panzer III
Installed the new gears, metal idlers from Artistic Hobbies came with ball bearings and M3 screws and a bushing. They're on rock solid and spin very freely. This is the single best, and cheapest, upgrade that a Panzer 3 should get.
http://www.rctank.de/Steel-Gearboxes...III-/-STUG-III
Old 09-21-2014, 02:01 AM
Cold Comfort
Wow, love it. Great work!
Greg
Old 09-21-2014, 05:19 AM
ausf
ausf's Avatar
Beauty.
Old 09-21-2014, 06:30 AM
Max-U52
Your black steel gearboxes have 48mm shafts, right? I only ask because the boxes in the photo are clearly 58mm. I've found that almost ALL the websites have mistakes in their photos like that. I know Erik is constantly having to check up on their site to make sure they're posting the correct photos.
EDIT: Almost forgot! GREAT work. I'm in awe. Those hinges are the coolest. Brand? Do you know if there are any more available? Those would be good just to have on hand. And PLEASE post photos/review of the new pin vise when you get it.
Old 09-21-2014, 06:33 AM
YHR
YHR's Avatar
Nice job. The Krylon paint is awesome. I use it like primer now. If I want a different shade I paint over it with a light airbrushed acrylic coat. For modern Canadian Amor it is almost bang on out of the can.
Old 09-21-2014, 07:27 AM
Panther F
Panther F's Avatar
I think I like this almost better than the Sturm-Infanteriegeschütz 33B SPG!
Nice work and a very clean build!
Jeff
Old 09-21-2014, 08:04 AM
Drew67
Wow, awesome work. Lots of nice conversion kits on the the website.
Old 09-21-2014, 03:14 PM
Strato50
Strato50's Avatar
Heh you are right they are the 58mm shafts. I just googled them quickly and posted the first correct image that came up as an example here
Simple cheap hinges here : http://www.ebay.ca/itm/221458455746?...84.m1439.l2649
Old 09-21-2014, 03:27 PM
Rex Ross
Where did you get the Machine gun on the top?
Rex
Old 09-21-2014, 04:45 PM
Martellus
That looks amazing
Old 09-21-2014, 09:09 PM
Strato50
Strato50's Avatar
Rex
It's the DP-28 from Artistic Hobbies
http://www.artistichobbies.com/prodd...hp?prod=JPZ080
Old 09-22-2014, 06:46 AM
MAUS45
MAUS45's Avatar
Looks Great. Nice upgrade to a Panzer III lower hull.
Old 09-22-2014, 07:04 AM
Cruiser133
Cruiser133's Avatar
Awesome Job! Damn you for posting this, now I have to get another kit to add to the long list of future projects! I already have an E-100, four PZiv variants and a Stug in the works. I will never get back to the Americans!! Very Cool.
Old 09-22-2014, 12:06 PM
Strato50
Strato50's Avatar
Hehe I know how that is... I now have 4 tanks based on Panzer III's only one of which is actually original It's the perfect hull to build on.
