Skymaster fa18 maiden flight
I KNOW THE MAIDEN FLIGHT ITS SIMPLE JUST HAVE SOME TRIMS AND CONDITIONS BUT WAS A GREAT DAY HOPE LIKE IT
https://www.youtube.com/watch?v=FdU1r1iADSo
A few shots of mine which is ready to go, along with 2 shots of the full size version. Im running a KT K170, Cockpit SRS, Hitech Servos all round, 1.2kg of weight added to the nose for balance. Just under 15.6kg in weight dry.
Thank you very much, this SM model flies so great, I had the yellow aircraft version too and o men that plane cause me a lot of headaches jajajajaja and its the perfect match between, power, size and agility......
Thanks for watch!
Thanks for watch!
Buddy just go anf fly it youre gonna be happy as hell, this plane its awesome, i was frightened because of my yellow f18 that plane was so difficult, but this model change me the opinion......
Send video when you do maiden
regards
regards
Thanks. I think that agrees with the website I found. ( my concern was whether it was showing the C or F model since the pics are of a C but the website title says F).
http://www.skymasterjet.com/arf18.htm
BTW, you must have awesome power with the KT170. Did you dial it down at all?
Just down to 120,ooo rpm, 3k under. There are quite a few of this model flying with the K170. Test flight should be in the next few weeks. Will be sticking a video on utube and linking it. ALthough you will have to put up with the maidens of both a Pitts S1s and S12 on the same link.
Just rejoined at Gouburn, NSW, junglejet after moving back from QLD. Waiting for my new MAAA card to turn up, it isnt the closest field 1hr drive. The local one wont allow anything noisier than a swallows fart.
Iain
Iain
let me know how your maiden goes. I have one here with the CG at 145, not yet flown but the same as the one it replaces.
Pete
Will do Pete, this Sunday depending on weather. I actually prefer a slightly rearward COG, and will probably end up moving it back. Im going to recheck everything Saturday as it is. How did you find it flew with the COG there.
Iain
Iain
Built for a mate, not yet flown but his previous C version was on the money at 145, same as another one over this way. Both guys happy with that set up. I fly the Fv and 1/8 F16, seems Skymaster like forward CG's. You going to Belconnen?
