Whats best way to attach heat blanket.
Looking to put a heat blanket on the top of the tail fuselage. Obviously from the pic the tail pipe will be touching the top of the fuse in
this plane (BD-5) due to modifications recommended by others. The pipe its self will help hold the blanket at the very end but as it
moves forward what would be the best way to attach it. I know epoxy gets soft with the heat. Would a resin mix work
if applied like it would be if you were adding a layer of fiberglass, then lay in the heat blanket instead? Ideas ??
I've had the same problem with the alum tape. Don't want to stick real good, even with prepping the glass, then the heat does in the glue.
Now the high temp RTV silicone,,,,,, haven't tried that
Thanks.........
Thanks.........
Automotive high temp RTV works great just clean/prep the surface. The aluminum tape doesn't work that well the automotive version of the aluminum tape sticks much better than the stuff you get from bvm/dreamworksrc.
My Feedback: (48)
What I like even better than RTV is Permatex Copper Spay-A-Gasket.
It's normally used to position automotive engine gaskets and hold them in place. Use it like contact cement. Just spray some on the ceramic blanket and a light mist on the fiberglass, wait half a minute and press the blanket in place. You can get it at most Auto Parts stores.
http://www.permatex.com/products-2/p...sealant-detail
After installation cover the ceramic blanket with aluminum tape.
I've done this on several planes, and it's held up well. I am a bit concerned about your pipe touching. It's best to have some air gap around the pipe. Maybe you should invest in a smaller diameter pipe.
Joe
Joe
I sandwich the the heat blanket with HD aluminum foil (heat blanket inside and aluminum outside). The aluminum foil helps the heat blanket to holds its shape and then use the RTV silicone as Jim stated to attach the fuse.
Works real well....
Works real well....
Here's the tutorial: http://www.rcuniverse.com/forum/rc-j...l-blanket.html
Thanks for all the great comments guys. I really like the cooper gasket spray idea also !! I think we're on the road to getting
this thing done..............
Sounds like you read my tutorial LOL.
