First Impression of new I gyro 3E ( Flying )
I am just back from 3 flights on the new I gyro 3E today. Over the past 6 -12 months, I have been getting great results from the Cortex units. I found the set up and in particular the "feel" of it in the air to be superb. I fitted the new I gyro 3E into my new Air C race L-29. Followed the instructions and set up as per the quick set up guide. I have to say. I am really, really impressed. Simple and quick to set up. Perfect feel at suggested throws and every bit as non intrusive as the Cortex in flight.
I am aiming to get some more flying in over the next week and start raising the gains, but so far I really cant fault it!
Please excuse the basic finish on the model. I simply threw some stickers onto the out of the box finish to get the test flights done before I get it painted.
I am going to stick my neck out and say its better. When the I gyro came out. It was exceptional. But when I first flew the Cortex. I have to admit that the " feel" was noticeably less intrusive, and dare I say it… Better.
The new 3E is every bit as good. I am not going to say better just yet as I have only had 3 flights so far. But its looking good.
Would i be right in thinking that the main difference (on paper) between the igro, the 3e and cortex is that the igyro has 1) gps adjusted gain and 2) allows you to adjust the gain on each axis.
In contrast the 3e and cortex only have a single gain setting for all three axis's. ( is this correct??)
If the above is correct then how does the single gain setting affect things in reality?
I am sure Richard will be along soon to clarify the differences ( Or someone who has spoken to Richard and asked the question ) For me the differences were in the way the gyro felt in flight and the simplicity of the set up. I am not sure what has changed in the computer Algorithm, but this gyro sure feels much more like its "not there" For me. Thats the most important quality that a gyro can have.
There is no external GPS module on the 3E. As I have just followed the quick step set up, and have not connected it to a computer. I am indeed adjusting all the gains on each axis in unison. I would bet that you can adjust them independently if you plug a lap top in. But for thats not for me. I use a gyro as a dampener. Not as a flight control system ( Contrary to what some people may say or think ) I only want it to smooth out the way in which the plane flies. So I find that I do not ever need to run the gains right up near the point where they are too high. With this in mind. I have never had a case with the Cortex's that I have flown where I have needed to adjust independent gains on each axis. The same with the 3E. I just went with the instructions guide for 40% gain and that felt perfect for me. Quick. Easy and reliable set up. All done pre flight and easily switched off if need be.
I will start to increase gains on the next flights to see what happens. Although I have a feeling that 40% ( As suggested by Powerbox ) is going to be close to where I want to be.
Powerbox said from the start to me the Cortex was designed as a helicopter gyro with changes to make it suitable for fixed wing. The iGyro3e was designed from day one as an aeroplane unit.
I don't want to detract from this thread about the Igyro3e but do need to correct factual inaccuracies about the Cortex. The Cortex is a dedicated fixed wing gyro. It is true that BavariaDemon have years of experience designing and manufacturing gyros for helicopters and they have therefore obviously used this experience with the Cortex. I'm not sure how this is a bad thing?
The Cortex is not 'PWM only'. It will accept 'bus' inputs from various manufacturers. It will, however, only output PWM signals.
My Feedback: (198)
Main difference is the iGyro is designed with BUS systems in mind and the 3e and Cortex are PWM only.
Hello,
the Heading is only active when the stick is in the middle. It holds the last angle (Aileron/Elevator axis) which you put your model in by stick. You donīt feel the heading but your plane flies 100% exactly.
If a gyro does this, it was not designed for fixed wing!
does keep returning the ship to it original heading after your imputs simular to the helicopter
My Feedback: (33)
So let me make sure I understand you correctly. say your plane is flying level left to right and you have heading mode on. You bank 90 degress and level out. Will the plane try to return to its last heading and will like the rudder be trying to turn it back? Or does it fly on the new heading?
If that is the case why would you need normal mode?
Thanks for your input.
QC, CANADA
Jeff,
Here is a great explanation of the diff between normal and heading mode (the explanation is for helicopters, but the global idea is the same):
http://www.rchelicopterfun.com/heading-hold-gyro.html
My Feedback: (33)
Jeff,
I understand how it works for Helos. I have used them before. I guess maybe less gain on the HH mode would allow you to overide the heading say in a bank turn.
Do you use the HH mode only when doing say rolls or loops to stay in line and then switch it off before turn out of the pass? I figured that was the only way to use it on a fixed wing aircraft.
I have tried on smaller aircraft using it on just the rudder for take offs and it worked great with enough gain but you needed to turn it off to make a turn.
I just can repeat: it doesnīt work like a helicopter heading. For sure when you roll your plane in a 90 degree, and donīt touch the stick anymore the gyro will hold this new 90° angle, why go back?
And: the iGyro Heading algorithm is unique: you donīt have to turn it off for starting and landing. You can let it on for the whole flight - no stall danger!
The iGyro3e will definitiv keep a twin engine model straight with heading mode on.
Okay so the i3 you cannot hook it up via Futaba Sbus unless you use a decoder. Is this correct? if so that is good to know since I only use SBus I will need to get the bigger brother.
Thanks you saved me the mess up of ordering the wrong unit, thanks the info. I wish I could talk you guys into making a power system just like the Robbe battery backer, I run SBus and the extra large gauge wire they use and the terminal boxes are what I like. I miss using powerbox items.
